Supercrew cat-back questions?
Okay.... I've got a 02 Supercrew 4X4 --- I want a cat-back system with dual polished tips side exiting behind the right rear (same location as stock pipe).
Now-- The only system I could find was the Magnaflow model 15772 --
5.4L Supercharged V-8, CC/SB, F-150 Harley-Davidson,
DUAL SAME SIDE EXIT BEHIND THE REAR TIRE,
2.5" SS tubing, 3.5" rolled/double wall/p-SS tips
Now --- Will this work on my Supercrew? Even though it isn't a harley model?
I DON'T want any loud sound.... I want it quiet.......
Is there another option I could do to get dual polished side exiting pipes?
tj
tj
if i recall the supercrew and the supercab are the same wheel base. the HD system should work. if you have the system coming out behind the rear tire you shouldn't have to do anything with the spare. just call Magnaflow and ask the Tech guys they should be able to answer your question.
