SuperCrew
Has anyone experienced leaking door or window
Old Dec 27, 2005 | 10:04 PM
Joe Logan's Avatar
I just bought a beautiful 01 KR Supercrew and have not even burned 2 tanks of gas in it. The drivers door is letting water in and puddling under or on the carpet. Has anyone else had this issue happen to them and how to fix. The Ford Dealer just gave me a company that can maybe fix but they did not return my call
Any help appreciated
Old Dec 27, 2005 | 10:58 PM
patshea098's Avatar
You coudl take it to like autozone or somewhere and tell them your problem. Alls it is, is the rubber sealents/caulking around your doors and windows that have rotted or jsut came off. They can replace it or you can yourself. Simple job
Old Dec 27, 2005 | 11:06 PM
Peladu's Avatar
If you’re sure it’s the door, then it should just be a door seal. I cant see it being too hard to do it yourself, cheaper too. Just my 1 ½¢
Old Dec 28, 2005 | 09:52 AM
Rockpick's Avatar
Moderator &
Passenger side?
If so, common occurance (not so much on the KR but on the SuperCrew). Search 'A-Pillar Leak'. You'll get several hits.
RP
Old Dec 28, 2005 | 10:30 AM
mesquillo10's Avatar
Run water along the seams and buy a tube of black RTV. Then you should be able to find the leak...
Put the RTV on any cracked seals too. It can't hurt. IMO
