Front shock replacement, question on new shocks
I just purchased some new Monroe shocks for my 2001 Supercrew. I noticed that the top rubber bushings and bushing washers are smaller than the OEM ones. Has anyone run across this with aftermarket shocks? Did I get the wrong ones? The actual shock looks the same.
Should I use the OEM bushings and bushing washers?
Has anyone installed aftermarket shocks with smaller diameter upper bushings? Any ill effects?
BTW, I used a 21mm wrench/socket for the top nut and, I think, a 20mm for the nut beneath the bushings. There was not enough room for a 21mm deep socket for the top nut on the driver's side due to some bracket in the way. I used a 10" cresent wrench. The lower nuts were 13mm. (This was on a '99; your results may vary.)
Thanks guys for all the help. I went ahead and installed the new bushings. It does not look so bad now. I did not realize that they get compressed quite a bit resulting in them "spreading" out. Once installed they looked similar to the OEM and do not look that much smaller.
Now I have to install the rear shocks. The upper shock nut looks to be very diffcult to remove. Not looking forward to that.
