Wet passenger side carpet
I've seen and read a lot of threads on this subject. Everything from leaky windshields to the famous third brake light leak. I feel that my problem is the AC Evaporator drain tube leaking, since I only feel the dampness after the AC is on fer a while.The real question I have is how do you get at the drain tube. I looked all over fer it in the engine compartment and from under the truck and I can't see it anywhere. I found the famous metal tube that no one knows does what or goes where. That ain' it! Anybody got a clue or better yet a picture.
Kenny
Kenny
Originally Posted by jpdadeo
I had a water leak I accidentally stumbled on while running an amp wire. The passenger side front was soaked underneath; it turns out the water was coming from the evaporator box that goes through the firewall. My dealer re-sealed the box and so far, (2 months) it hasn’t leaked.
