SuperCrew
Need Help. Engine miss/hesitation with A/C on?
Old Jul 11, 2005 | 11:42 AM
chuka's Avatar
Help!!!
I know someone on here can help me. I have a 01 F-150 Supercrew with the 5.4L and 4X4 and Auto trans. It has about 85K miles on it and last week it started acting wierd. If I turn on the A/c when the engine is cold (not warmed up), the engine acts like it wants to die. It rattles and misses. Turn off the A/c and it clears right up. I am confused because when I say the engine is cold, it is sunny California here right now so I am not dealing with extreme cold temps. It just like to warm up before I run the A/C. Today, the problem seemed to take another step up on me as coming to work this morning, with the A/C off, I set the cruise on 72MPH and it would surge. Kind of like a cruise control module going out or somehting. Closer to work, it also cleared up, so I am stumped. Any help or advise would be greatly appriciated as I am planning a very long trip in the next month or so and will be pulling my boat so I need her running strong.
On a side note, replaced the brakes this weekend (due to the typical Ford warped Rotor effect) and found out something kind of cool yet odd. Before I did the brake job, I noticed my Em. brake light would not go out despite the brake being completely released. I had a hunch that maybe Ford tied in a low fluid sensor to that light and low and behold, they did. Added some fluid and the light went out. Did not take much as I knew when I changed the brakes, I would have some spare since the pistons in the calipers would be fully compressed. Just thought I'd share. Chuck.
Old Jul 13, 2005 | 01:02 PM
Bluegrass's Avatar
You posted in another thread where I told you about a possible signal interference with a cable to close to the dryer.
Did you check this out?
It was not meant to be amusing to you but a real condition that has been known to happen when the A/C is being used.
Old Jul 15, 2005 | 07:44 AM
chuka's Avatar
I did take a look but which 'cable' are you refering to? Thanks.
Old Jul 15, 2005 | 11:31 AM
dburgjohn's Avatar
Mine was doing that and it was the IAC valve.
