Ut oh!
Ut oh!
When I turn the rear end squeeks and makes a horrible sound, shimmeys, jerks and is "bumpy". It only does it when I turn and give it gas at low speed(5-15mph).
what are some things I should check? This all started happening about 1-200 miles after I got an oil change at pensoil. Could it be the oil? Or is it something like a loose u bolt or something?
Thanks.
Thanks.
You're talking about the "clutch pack" in the rear?? Positraction??
How many miles??
Why not get some additive first. For Positraction/Traction Lok. Add it to rear. Take truck to large empty parking lot. Do three/four tight, wheel against steering stop to wheel against steering stop, slow figure "8"s.
That should take care of the noise. I've fixed MANY nosey Posi rears that way.
Not too expensive either.
How many miles??
I would have the oil changed and new additive added. I had a similar problem with a Trans Am. After changing the oil and adding fresh additive I never had another problem in the next 8 years that I owned the car.
Originally posted by kmk17mx
And also, I pour the additive in the transmission oil, right? What kind of Positraction/Traction additive oil do you recommend?
update: just changed out my crappy vavoline oil to mobil 1 synth 0w-20. Helped alot, but still noticable.
just bought some TransX posi friction additive tonight. not sure if it is the right stuff? says not to use in automatic transmissions, or ATF.
Where is the rear end fluid located?
Thanks.
Thanks.
BH: Shut up Beavis.
Sorry, couldn't help it.
WTH is going on here? If changing his motor oil from Valvoline to Mobil 1 "helped alot" with the diff. chatter, I'm beginning to wonder which end of this vehicle is the front, and which is the back.
Not to be an AH or anything, but if you have to ask where the rear end fluid is located, you should definitely consider getting some assistance from someone with juuuuust a tad more automotive know-how.
That, or this just a goof thread.
SL
