SuperCrew
How to pull off door panel
Old Mar 2, 2005 | 09:44 PM
Miles73003's Avatar
How do you get the driver side door panel off on a supercrew? Just wanted to cheack here before I do it. I am guessing you just pop out the control switch thing first and then from there you can pop it up and out. Ive done it multiple times on my mustang but never on the truck. There is a rattle in there that is driving me INSANE. Thanks ahead of time.
Old Mar 2, 2005 | 10:54 PM
Capt JJ's Avatar
Pop off the window switch panel , few bolts there to take loose, couple of screws at the bottom of the door panel, then pull up and out she comes!
Old Mar 3, 2005 | 08:03 AM
LightningCrew's Avatar
You also need to remove the trim piece from around the inside door lever and there is one or two screws under there (at least there is on my 2001).
Once you remove all screws (total of four or five), grab the door handle and slide the panel upwards. You will need to disconnect the red "open door" warning light on the backside of the panel once the panel has come away from the door.
