SuperCrew
Spare tire problem
Old Sep 25, 2004 | 01:36 PM
jnb412's Avatar
Spare tire problem
I priced tires the other day and was stunned to find that to replace the ones I got on there go for about $200 a piece. The guy at Goodyear said I could save 25% buy using the spare. Good idea I thought...
Today I cranked the spare down (only the second time in two years) and found it had a bunch of burn marks in it from the frame. The were exactly symmetrical and lined up perfectly with the frame.
Anyway, I thought I'd warn y'all.
Old Sep 26, 2004 | 08:31 AM
Gearhead99's Avatar
I took my spare down to use after 3 years. It had several "marks" from the frame. Don't exactly know what you mean by "burn".
Anyway, I used it anyway. It cleaned up good and after about one week the marks are undetectable.
Old Sep 26, 2004 | 02:14 PM
jnb412's Avatar
I don't know what else to call them... If my pinkie finger were a hot dog, it would fit in there like a bun. Eight little burns...
Maybe a photo is in order as well as a visit to the Ford dealer.
Joe
Old Mar 16, 2005 | 07:20 PM
JCCOULTER's Avatar
Spare Tire Problem
I also was very suprised to find that my spare had 8 frame burn marks in the sidewall. Apparently mine were worse that yours becuase mine were all the way down to the cord making my spare unuseable. I had purchased 3 new tires and was planning on using my spare that had never been lowered as the fourth tire. I guess that is now out of the question. My dealer said they had never heard of the problem before and it was not coverd under warranty.
Old Mar 16, 2005 | 07:33 PM
max mitchell's Avatar
Yes, it's very typical. I've read posts about this, every once in a while, since I've been a member here. If it's cranked up hard, it makes deep grooves. If the spare is not maintained, it will lose pressure and rub as it moves. After I read about it the first time, I sandwiched some rubber backed carpet on my truck, cranked carefully, and closely maintained the spare.
Old Mar 17, 2005 | 04:21 AM
MikeF150's Avatar
Try placing some 1"x3" pieces of wood on top of the spare between the tire and frame and then crank the spare back up.... I did this a couple of months after buying my truck and the spare is fine...
Old Mar 17, 2005 | 02:24 PM
MITCHYKINS's Avatar
put my truck up on hoist to do the oil change @ 45000 kilos
no spare cable broken not rusty or anything spare gone
must have worked loose then snapped
mitchykins
