SuperCrew
A/C jumping from panel blowing to defrost
Old Aug 20, 2004 | 11:12 AM
big jws's Avatar
Just wanted to see if anyone else has had this problem...all of a sudden, my A/C won't blow from the dash anymore. Yesterday I put it on Max A/C, it started blowing from the dash vents, then switched to the defrost vent, then back to the dash vent, etc. Now it's only from the defrost vent...anyone have any info or experience on this problem? '97 F150
Thanks!
Old Aug 20, 2004 | 07:48 PM
wattman1's Avatar
Unhappy Don't Know for Sure
big jws,
Don't know for sure about the 97 F150, but I had a Jeep before that had similar symptoms. It turns out that during a radio install, I had inadvertently loosened a vacuum line in the dash (on the back of the Temp Controls) that caused this same problem.
You might be able to tell from a Haynes manual (or similar) if the 97 F150s have the vacuum lines controlling the air flow.
Good luck!
Wattman1
Old Aug 20, 2004 | 11:38 PM
Gearhead99's Avatar
You have a vacumn leak somewhere.
Old Aug 21, 2004 | 02:35 AM
chuka's Avatar
Hey big jws,
I had this same prob only about a month or so ago. The first few days it would cycle back and forth from the dash to the windshield/defrost vents. I have attahced the link to the thread if you would like to check it out. The problem with mine was a bad check valve in the A/C system. It is located somewhere near the accumulator. I went ahead and had my mechanic R&R it and it only set me back about $80 total (parts & labor). Hope this helps. Chuck.
-------------> Click Me !!! <-------------
