F150 Supercrew body lift
I have a 2002 F150 Supercrew 2wd and i was wondering what size tires I could clear with this. I want it to look clean and dont want too much tire. Please help me!(I already have 16X10 rims)
Originally posted by JasonJ
From what I have read on here if you have a 3" body lift you can clear 33's with a 2wd
You could run 285/75-16's(33x11.40) or 305/70-16's(33x12.50) on the stock 16x7's. If you have 17's ,you could run 33x12.50-17's or 285/70-17's(33x11.50). If you plan on keeping the stock wheels forever, you would be better off with 285's. The wider tires (305's and 12.50's) are a little wider than the manufacturer recommends for the stock 16x7 and 17x7.5 inch rims. While they will fit, they will probably wear slightly faster in the center portion of the tread because of the narrow wheels.
