SuperCrew
Rear Slider
Old Apr 26, 2004 | 01:33 PM
jeffcrew's Avatar
Rear Slider
I know there has been much discussion regarding leaky rear windows in the 2001 screws. I will be having mine replaced due to breakage and I want to make sure I get the potenetial leaking problem fixed in the process. I am confident that the Ford replacement will use the new seal design as in the 2003 models. Has anyone used a CRL aftermarket slider? and do they use the improved seal system.. they are $150 less expensive than the Ford replacement. Any experience anyone has with aftermarket rear sliders would be most welcome.
Old Apr 27, 2004 | 10:48 PM
KCWWTP's Avatar
C.R. Lawrence used to produce the power slider rear window that was an option on the fords in the early 90's (man i feel old saying that). They used to produce pretty good quality windows & sunroofs. I would feel pretty confident in installing a CRL slider. The old days, when I first started in the autobody trade (1987) the window was simple to install...today a different story.
Good luck!
