SuperCrew
no brake/turn signal lights
Old Mar 29, 2004 | 09:40 PM
schumann129's Avatar
My turn signals started flashing faster, I checked the rear and both the turn signals and the brake lights did not work. However the reverse and driving lights did work. I checked both lights and they were ok. The fuse was also ok. The strange thing though, when I had the rear light housing off, I decided to switch the bulbs, the back up/running lights with the brake/turning lights, and the opposite happened. Now the brakes and turnsignals worked, but now the reverse and driving lights did not. Any help?
2003 F150 supercrew, lariat 4x4
Thanks,
Greg
Old Mar 30, 2004 | 08:17 AM
screwdup's Avatar
Hi-
Try it with your tilt wheel all the way up and then move it down. If it makes a difference you a known problem. Do a search, there are several posts the explain the fix.
Old Mar 30, 2004 | 09:41 AM
serotta's Avatar
found these:
https://www.f150online.com/forums/sh...nals+dont+work
https://www.f150online.com/forums/sh...ignal+problems
Old Mar 31, 2004 | 02:28 PM
J-150's Avatar
probably the multi-fucntion switch.
it's a common thing with the 97-03 F150's.
