SuperCrew
Rattle in 2002 Screw Dash
Old Jan 12, 2004 | 10:39 AM
BamaScrew's Avatar
I have a rattle in the drivers side dash where the defrost vent is. i have had it in the shop twice to be fixed each time i leave its ok for a day or so and then its back. anyone else have this problem or has had this problem and what the fix is or may be....thanks
Old Jan 12, 2004 | 05:15 PM
keeper15's Avatar
i also have a rattle that bothers the hell out of me...it sounds l;ike a rubbing of the dash and other plastic dash parts, maybe a screw or fastner...on the right side....it is very noticeable around freeway driving or any non smooth driving surfaces...
Old Jan 13, 2004 | 10:27 AM
BamaScrew's Avatar
sounds like the same thing
Old Jan 14, 2004 | 10:07 PM
CJW's Avatar
CJW
I had the same problem, but luckily found it. There is a little black sensor in the middle of the dash on the top side. When you are driving down the road and you here the rattle , reach up and put your finger on it and see if it goes away. Hope this helps
Old Jan 15, 2004 | 08:16 PM
canyonslicker's Avatar
Mine ended up being the fuse box under the hood. It started after installing electric fans and I attached a wire underneath. A small piece of rubber wedged between it and the body , Presto noise gone.
Good luck
