SuperCrew
Power Door Lock failure
Old Jan 7, 2004 | 09:44 PM
Smithy's Avatar
Unhappy Power Door Lock failure
I hate to say but my first problem has occured. The rear door power lock has malfunctioned on the drivers side. It is in the locked position and cannot be unlocked electrically or manually from inside. All 3 other door power locks work fine. Guess I will be going to the dealer tomorrow unless some one has a quick fix.
Old Jan 7, 2004 | 10:40 PM
serotta's Avatar
You could try disconnecting the battery for a short while, then unlock the door manually. If that doesn't work I'd say the problem is not electrical, but mechanical.
Old Jan 8, 2004 | 08:21 AM
Smithy's Avatar
Talked with the Dealer and set up an appointment. They said that it may be cold induced by the zero degree temps we are currently experiencing. I do not believe it.
Old Jan 8, 2004 | 09:38 AM
LightningCrew's Avatar
Smithy - before you go to the dealer, check to make sure the child lock was not accidently engaged. If you open the door and look at the "back" of the door, there is a child lock. I had this happen the other day - figured out that it had probably been hit when I had the truck washed.
Old Jan 8, 2004 | 12:44 PM
Smithy's Avatar
The problem is that I cannot open the door at all. Pressing the unlock button has no affect, I can't even pull up on the door ****.
Old Jan 8, 2004 | 12:50 PM
rogone's Avatar
It sounds like all the problems you are having would not likely be caused by cold weather. I've had doors and locks freeze up but atleast something would always still work even if I couldn't get the door open or unlocked. Good luck at the dealer. Let us know what you find out.
Old Jan 9, 2004 | 08:57 AM
Smithy's Avatar
Smile
I may be having a piece of humble pie today. On the way to the dealer to get the power door lock fixed, just before turning down their street I gave the power locks a few quick flicks and the one that has not worked was working! The mechanisim was proboably frozen. It has not gotten above freezing for several days now, but maybe the heat from inside the truck got to it. Bottom line is it is fixed, no need to put it in the shop. I am happy again.
Old Jan 9, 2004 | 11:46 AM
serotta's Avatar
Glad to hear it was something simple. Down here in the sunny south we usually don't worry about such nonsense. Given the large group of members from the "frozen" north, I'm suprised this hasn't come up before.
Old Jan 10, 2004 | 11:55 PM
Hey, glad it fixed itself - probably something with the famous "Ford" wiring. You know the one-touch down window on the driver's side?? Mine quit working for about a week and then all of a sudden it started working again. Couldn't connect mine with the temp, though.
Old Jan 25, 2004 | 01:28 PM
benm5678's Avatar
I have the same problem on my brand new 2004 Supercrew... what a disappointment -- not even a month on the road (700 miles on it) and both rear doors would not open suddenly. On one of them I was able to manually pull up the lock and open the door (almost as if the automatic mechanism did not have enough power to push it all the way up) -- but the other door is still jammed locked... I see the lock moving up and down, but it's not rising high enough to unlock the door. The temps here have been in the 20s... but please.... if Ford trucks don't work at this temperature they're a piece of sh***t.
I'll be going to the dealer and it sucks... they better not make me pay my warranty detuctible.
Old Jan 25, 2004 | 04:40 PM
NotScru'dYet's Avatar
There is no deductible under the factory warranty.
Old Apr 18, 2004 | 02:56 PM
cheeks's Avatar
oops...wrong thread
