Paint Code
Open the drivers side door and look under the center piller by the threshold. There will be a label with a bunch of info on your truck. Down below the bar code you will see something like Ext Pnt. To the right should be a two letter code. Thats your paint code. If you have a two tone paint job there will be a second two letter code to the right of the first code, that is the second color.
oxford white
Keep in mind that white is one of the hardest colors to match.
There are about 5 alternates of your paint color which is very
typical of late model vehicles. You can go to an automotive
paint & body supply. Provide your color cde & vin# and they
can look up the alternate that most closely matches your truck.
Good luck.
Good luck.
