SuperCrew
Engine Noise and AC
Old Nov 15, 2003 | 02:33 PM
ping70's Avatar
Engine Noise and AC
Has anyone noticed a noise in there engine like a knocking noise while you are in idle or driving. Also, my AC cycles on and off every 20 seconds and clicks loud each time it does it. Is anyone else experiencing this problem. I only have 700 miles.
Old Nov 15, 2003 | 03:32 PM
KingJR's Avatar
My 97 explorer used to cycle the A/C every 20 seconds too...very loud clicking.
One thing I noticed is the Engine was idling at 500 RPMs, if I just barely stepped on the gas pedal the A/C would stop cycling on and off. I ran the RPM up to 700 and the problem went away.
--Justin
Old Nov 15, 2003 | 04:32 PM
ping70's Avatar
It does it even when I am driving. It's driving me crazy
Old Nov 19, 2003 | 09:31 PM
Yankee7985's Avatar
Sounds like it could be the A/C cycling switch located on the receiver dryer near the r/h side of the firewall.
Old Nov 20, 2003 | 12:22 AM
ping70's Avatar
so what should I do Yankee?
Old Nov 20, 2003 | 08:20 PM
Yankee7985's Avatar
The cycling switch is very easy and inexpensive to replace. I bought mine at the dealer for about $12.00. It is a schrader type valve which means it will not leak when removed. You will loose a minute amount of freon when you unscrew it. After you remove it, install the new o-ring on the new valve. You can use a little of the freon/oil from the switch and/or boss to lube the o-ring before you install it on the new switch. After you do this, just screw it back in and reconnect the harness. You're done.
Old Nov 20, 2003 | 09:28 PM
ping70's Avatar
Does that go for a 2004 as well
Old Nov 20, 2003 | 10:05 PM
Yankee7985's Avatar
Not sure.
