SuperCrew
Adding on Autolamp
Old Nov 18, 2003 | 06:26 AM
rogone's Avatar
The thread on using fog lamps with auto lamp describes how to take the switch out. Here's the link: https://www.f150online.com/forums/sh...hreadid=134323
Old Nov 18, 2003 | 06:38 PM
danike's Avatar
That link is the begining of this thread.
Old Nov 20, 2003 | 08:15 PM
rogone's Avatar
Sorry about that danike, I would have corrected this sooner but I have been out of town. Go to http://www.svtlightnings.com/ , then click on "how to" on the left column, then click of "fog lamp rewire". Good luck.
Old Dec 3, 2003 | 10:04 PM
danike's Avatar
I did the foglamp mod to my to my light switch to work in all positions except off. The switch works fine, but the part of the mod where the white/black wire and brown wire gets spliced together causes the "foglamp relay/foglamp light" 5 amp fuse to blow under the dash and the foglamps won't work with the splice removed. Should this splice be made with a inline fuse? I found this out when I ran a jumper wire from the white/black wire to the brown to make sure I had the correct wires before splicing.
