I Need More Boom
I Need More Boom
DOES ANYONE KNOW WHERE I CAN GET MORE BASS FOR MY SCREW, I HAVE THE HIGHS RIGHT NOW BUT THE INSTALLER WAS TALKING BIG BUCKS FOR ME TO HAVE SOME BOOM AND I`D LIKE TO SAVE THAT FOR SOME WHEELS AND OTHER ADD-ONS.
I think if you look in the audio forum you will find more answers than you know what to do with. Here is what I am considering. Using Supercrew Sounds box with 2 Kicker Solo's L7's. I am planning on using the 2 8" square woofers with the dual underseat box(all fits under the biggest part of the rear seat).
I was gonna try to link for you but the server is down I think.
I think it is www.supercrewsound.com Check it out or look at Probox rocks.
If you have any skills at all, you can make your own sub box for the center console - I did this and spent maybe $60. 8" sub - I know, it is only 8", but I was very surprised with the bass this thing put out. The thing I liked about it is that it is totally stealth - you can still use the factory tray in the console. Here are a few pics:
NOTE: The speaker wire connections had to be removed because they were allowing air to leak. Ended up covering the hole, caulking, running the wires thru a small hole and caulked, and recoating with bedliner spray. Dimensions for the box are in my gallery.
Originally posted by RDB2Screw
Here's the Stealth by Clarion not too overwhelming but sure adds punch to stock setup....
robert
This comes with the amp built into the sub. Its an 8 inch downfiring sub, and with a simple wiring harness (I got mine from crutchfield) it plugs in directly between the stock HU and sub enclosure.
or you can get one cheaper at:
These guys have Clarion Subs for $100. They are not brand new, but close
Give Tony a call
Call us at 800-499-2277. Thanks
Bass Sales
1479 N. Linden Ave
Rialto, CA 92376
800-499-2277
