AMSOil
AMSOil
I don't want to start any debates on oil here, but just for everyone's info, AMSOil makes a synthetic 5w-20 oil. On their web site, it's 5.20 a quart, but if you sign up for their prefered membership, it's like $20 a year, and the price drops to $3.95 a qt. I purchased a membership when I changed my transmission fluid, and now for oil. They have a ton of products, personally I like them.
Rick
Rick
membership
Is that for mail order on there web site, what does shipping cost.. humm i will check that out, How long do you run with your amsoil, also I am looking to change the ATF and use amsoil any thoughts on filters. are any better or worse, what to stay away from on that, as far as oil so far i just use Mobil1 5w30, and Motorcraft filters.
Here is the deal on mobil 1 vs amsoil Amsoil vs Mobil 1
The cost of shipping, it tells you before you order it. Comes UPS
Messman24, I just switched to AMSoil, and plan on going about 5000 miles between changes. I tow regularly, so I like to change regularly and early. They say you can go 7500 miles between changes. As far as filters, I use the motorcraft filter.
On the ATF, I bought a filter from the local autoparts store. I sugesstion, take a good look at your pan first, and count the bolts. I was given two wrong filters before they found the right one. With their ATF fluid you can go 90,000 miles between changes. I will plan on about 50k though.
Rick
Rick
