SuperCrew
ac problem
Old Aug 16, 2003 | 11:30 PM
bergsf150's Avatar
ac problem
I have a 01 screw with a little problem. Yesterday I was at a stop sign and had the a/c running. The engine usually idles about 600 rpm in drive with the a/c on. But today the engine started to surge from 600 rpm to just over 1000 rpm. it did this for a couple of cycles then stopped. Then it started it again a few minutes later. it has never done this before. Anyone ever have this problem?
Old Aug 16, 2003 | 11:54 PM
Rockpick's Avatar
Moderator &
Weird...
First, has it ever done this before? Second, if so, was the AC on? It just seems to me like it's probably a coincidence that the AC was on when it did it (but, it might be the issue...).
Are you still under warranty?
RP
Old Aug 17, 2003 | 09:45 AM
bergsf150's Avatar
yes still under warranty. and yes the a/c was on but this was the first time that it has started to surge with the a/c on. I have owned the truck since it was new.
Old Aug 17, 2003 | 05:35 PM
Capt JJ's Avatar
IAC
IAC solenoid sticking, happeneing on thousands of Ford vehicles a week. I bet in the past month we have replaced 20 solenoids per week if not more on Lincoln/Mercury's!
