Utility Bed Available for S'Crew
I have a 2001 S'Crew 2wd XLT w/ 5.4L that is used primarily for Emergency Fire/Rescue Response.
Does any company out there make a utility bed (cabinets/extra storage options) for the SuperCrew?
I know several years back, a company was out there that made a subdued utility type bed...more or less, it was a utility bed that was less "boxy"...it looked very similar to a stock utility bed but had 3 cabinets on each side using the space above, behind and in front of the rear tire as storage space. Yes, it took some space from within the bed as well to do this, but still left a 4'x8' box between the wheel wells.
Any ideas folks? I could use other practical storage places other than just a toolbox...and wouldn't mind getting rid of the toolbox alltogether!
Thanks in advance,
Steve
Thanks in advance,
Steve
There are quite a few sites to search. Here is one.
http://www.tool-box-store.com/single...uck_boxes.html
I hope it helps. Have you beefed up the rear springs?
TruckVault is perhaps one of the better known
solutions. Here are a couple of links about TruckVault. You may very well find others via searches both on the net and here in the forum. Others here have come up with some home made storage solutions. I'm building one myself right now, but it doesn't sound like my scenario will fit your needs.
Check out the command center on the link immediately below.
http://www.truckvault.com/
http://www.edasc.org/EDASCnews/compa...truckvault.htm
Tom Hall
Tom Hall
