Sliding Rear Glass Removal - IMMEDIATE HELP NEEDED!
Trying to remove the sliding rear glass out of my truck. All 12 9mm bolts have been removed and I can't budge the glass. By theory, the glass should 'pop right out' but, at this point, it's impossible.
There is a butyl seal around the edge of the glass and I think that is all that's holding it in place.
Has anyone removed this glass? If so, can you PLEASE help me out here...
THANKS!!!!!!
RP
THANKS!!!!!!
RP
Look at the CRL instructions I sent you. Using a putty knife break the seal with the knife while gently pushing outward to your helper. There will be some buytel gasket left on the truck that you will need to scraper off with a knife or razor blade to get a clean smooth mounting
