Injector size option for 5.4l??
Re: Injector size option for 5.4l??
Originally posted by Way2Big
Hey guys just wondering what sizes are available.So far all I have seen is the 42#. Also, do the stock fuel rails handle them well? Thanks!
Since I live in the SF Bay Area and we may soon be subjected to the dynamometer smog test, I do not want to inadvertently go overboard on any of my add-ons.
What I would like to do, my current thinking, is to go with an ATI, 10psi pulley, 90mm MAF and large enough injectors to allow me to dump the FMU.
Does this combination automatically dictate 42# injectors or would 30# or something in between be adequate or, will it not make any difference with regard to the smog test as long as my chip is properly burned to give me the correct A/F ratio.
I know that when I have to go in for my first test, I will be sent to the state operated station due to the supercharger setup and they are likely to be super critical. As I am sure many of you know, one test failure can open up Pandoras Box and it can be a real B@#$% to get the lid back on.
Unless I am mistaken larger injectors dont mean you will get more fuel and hence screw your smog test. With stock inujectors you need high preasure and a long duration to get the proper amount of fuel. If you go with #42 you wont be using more fuel than is needed. The injector, since it can flow more due to a larger apature, simply uses a shorter burst of fuel but the end result is still the same, its computer controled. The big difference comes at high R's where stock cant deliver enough fuel the #42's will be able to keep good air/fuel numbers.
Zyg,
Your response confirms my understanding of how the system functions however, there has to be a point where the injector becomes too large and either the pressure needs to drop below that neccessary for proper atomization or the pulse needs to be too short for proper control.
I would have to assume that the 42# size is sufficiently below that critical size, whatever it is, (as evidenced by their being standard on L's) that it will not enter into the equation.
Check out this link for some various recomendations by ProM
http://pro-flow.com/tech%20info/sizing.htm
Originally posted by madferraristi
Based on that information, any time we install 42# injectors, shouldn't we should also upgrade to 1/2" rails?
Maybe Crash! or Skidmark will chime in and give us better clarification.
