parts list for the N/A 5.4 to Eaton swap
Old May 21, 2016 | 12:17 AM
Veteran: Army
  • supercharger
  • throttle body
  • lower intake (commonly called a turkey pan)
  • midplate
  • intercooler core
  • supercharger belt tensioner Pulley Bridge with belt Tensioner Assembly (Bracket with idlers and special bolt spacer) (spacer specs to be posted later) -
  • Lightning Alternator (Lightning / Harley truck specific to clear the turkey pan)
  • Alternator Stabilizer Bracket
  • Intercooler Pump and Pigtail (Bracket NLA the pigtail can come from an EV1 style plug injector harness)
  • Intercooler Reservoir with Cap (stock tank requires a Lightning / supercharged Harley truck fan shroud)
  • IAC Tube
  • Throttle Cable
  • Throttle Cable Bracket
  • Cruise Control Cable
  • IAT1 Sensor (fits in air cleaner)
  • IAT2 Sensor (screws into the lower intake / turkey pan)
  • Lightning Specific Water Pump or N/A F-150 pump with Spacer
  • PCV Tube (left hand side)
  • PVC Tube (right hand side)
  • TB to MAF Rubber Connector with clamps
  • 90mm MAF - stock pulleys can get by with a stock 90mm MAF anything past that, you might as well get a good one straight out
  • Intake Gasket Set Available
  • In-Tank Fuel Pump (single 255lph pump minimum)
  • Upper Radiator Hose (N/A one is shaped differently)
  • Upper Two Intercooler Hoses
  • Original Equipment Installation Bolts (lower intake to heads, the N/A F-150 ones are too long)
  • Drive Pulley with Belt (Boost level of your choice) - might as well go for a 4#lower and stock Lightning upper
Old Jan 31, 2017 | 10:33 PM
Veteran: Army
guess I better add the bolt info
Originally Posted by Kirst8404
From an old post I made for Oldtimer. Doesnt have all the ones your looking for, but its something.
EGR- M8x1.25-30mm (qty 2)
IAC- M6x1.00-30mm (qty 2)
MP Snout bolts - M8x1.25-45mm (qty 6) - normally qty 8 but...
This part is not normal - MY LOWER BOLTS WERE STRIPPED ON THE CASE AND RETAPED TO A LARGER SIZE> 3/8-16 x 1 1/2 (qty - 2)
Boost Valve - M8x1.25-18mm (qty 2)
SBTB - M6x1.00-25mm (qty 2) I needed to reuse the bottom studs for the throttle bracket.
Throttle bracket - Nuts - 6mm (qty 2)
JLP Plenum to MP- M6x1.00 - 25mm (qty 5)
Fenders - M6x1.00- 20mm (qty 6)
Alt bracket top - M6x1.00 - 20mm (qty4)
Them I bought a bunch extra of M6x1.00 - 25mm and found more spots around the engine bay - Fuel rails, Sensors, Top of my JLP Intercooler tank....Some extra M8x1.25 x 25 - Hood bolts, hinge bolts.....
The Blower Bolts are M10-1.50x100mm.
thanks :bigtu :bigtu
Old Feb 7, 2017 | 02:33 PM
BROTHERDAVE's Avatar
25 Year Member
to me trucks is this age group are either high millage ready to retire or perfect low millage vehicles. is this swap still being done very much?
Old Feb 10, 2017 | 08:42 AM
Veteran: Army
lots of hopefuls wanting to swap, without the cash flow to do so, and a few show vehicles. (I'm just keeping the info out there )
Old Feb 12, 2017 | 11:47 PM
01Screw17's Avatar
I appreciate it! I've been thinking about it for a while now... does anyone know of any good kits out there for sale? I'd like to get everything together and minimize piecing things together.
Old Feb 15, 2017 | 05:51 PM
Veteran: Army
I have one in my garage...
Old Feb 15, 2017 | 08:34 PM
01 gt f150's Avatar
One for a 4.6??? lol
Old Mar 2, 2017 | 11:19 AM
01Screw17's Avatar
That you would be willing to part with?!
Old Mar 19, 2017 | 12:54 AM
Veteran: Army
IF someone had the money...
Old Jan 28, 2018 | 03:32 PM
Timmah7286's Avatar
Parts
Still? What parts? How much?
Old Feb 24, 2018 | 01:56 PM
Veteran: Army
I gather parts randomly as I find them, I have one 90% (needs MAF, injectors, tuning device, intercooler tank, h/e and pump) setup and a 30% (lo wer intake, midplate, intercooler core) setups currently...
Old Sep 25, 2019 | 08:53 PM
John Wicks's Avatar
Just wanted to thank you for the list. Started my swap today into a 2000 F150 NA HD. Got 02 complete engine and tranny with all the goodies listed.
