Running 10+ PSI with Whipple...
Old Oct 8, 2014 | 05:31 PM
radelow's Avatar
So my Whipple Kit arrived. I also picked up a 3 inch pulley and 95mm MAF kit to run ~11-12 PSI boost. I want to make sure I have everything dialed in for the additional boost. In addition to the above I will be running:
1. 255 LPH Walbro Fuel Pump
2. 47# Cobra Injectors
3. Steeda Belt Tensioner
4. Larger Heat Exchanger
Anything else I need to be doing for the additional boost? Should get everything installed in the coming weeks. Vortech kit will be going up forsale soon!!
Old Oct 8, 2014 | 06:03 PM
twinskrewd's Avatar
A good tune! You'll be set.
Old Oct 8, 2014 | 06:34 PM
IR0NS1N's Avatar
I ran a 3" pulley before going Metco lower and stock upper. It had slip issues at times. I made my belt crazy tight to remove the issues but my idler bearings didn't last real long after. Honestly Metco crank pulley and stock upper is better then 3" upper.
I also run Cobra 47lb injectors, Thump RRR tensioner, stock heat exchanger and stock fuel pump.
Old Oct 9, 2014 | 12:11 AM
Especial86's Avatar
Got a part # for the metco lower pulley?
Old Oct 9, 2014 | 04:50 PM
twinskrewd's Avatar
The Metco pulley is MCP2005.
Old Oct 13, 2014 | 10:36 AM
IR0NS1N's Avatar
Whipple kit comes with HTO plugs, but he should change the tstat to 180 instead of the 160
Old Oct 13, 2014 | 12:51 PM
radelow's Avatar
I am using Ford Racing colder plugs. When I put the new built motor in the Ford Racing heads were the new design (no more two piece plugs...YEAHHHH!!!!)
These plugs FYI:
http://www.americanmuscle.com/frpp-1...gs-0810gt.html
Also I did pick up a 180 degree thermo.
Old Oct 13, 2014 | 01:04 PM
twinskrewd's Avatar
Are you going to run twin 255lph? Otherwise switching to a single 255lph would be a mistake. The stock pump is rated at 310lph if I remember correctly.
Old Oct 16, 2014 | 01:15 AM
radelow's Avatar
Pretty sure the stock pump is rated at 91 lph @ 45psi.
Old Oct 16, 2014 | 08:28 AM
twinskrewd's Avatar
Old trucks none flex fuel yes. The newer ones are much better. Keep in mind Whipple supports 12psi on the stock fuel pump with upgraded injectors per the install manual. That would not be possible with a 91lph pump nor a 255lph pump. My twin 255lph pumps with 60lb injectors were at 60% duty cycle running 12.45 psi maintaining an a/f of 11.22.
