turbo size input
turbo size input
This would be going on a 99 5.4 automatic 4x4.
Came across a decent deal on a garrett turbo. The inlet side, aluminum cover says A/R .50 M43. On the part that you mount to flange in there it has a stamp of .63.
There was no plate with model number anywhere. There are however a set of numbers.
on the center section there is 430683 -11 cast in housing.
On the exhaust flange there are also two number cas on each side: 20357 on one side and 0358 on the other.
The exhaust side outlet measure at 2.25 inches. The intake side where the filter goes measure around 3 inches.
I measure the inlet side wheel to figure out the trim... 3 inches for the larger fins and 2 inches for the smaller fins.
If my calculations is correct come out to be right around a 43 trim...
Anyone have input if this would work on my 5.4? I'm only looking to push around 6-8psi....daily driver of course.
Anyone that know more about turbos, is this too small or will it work? I googled and really didn't find to much info. The little I did find most of the number didn't match to what I had.
If the .63 is correct on the exhaust side it should spool up nicely. I guess the trim is where I would be hurting. Would i Just run out of power on the top end, or would it just come on to quickly?
Thanks for any input.
i have the same engine and wanting to go turbo as well.
its assumed you plan on a remote style setup.
i dont know much about garrets but that sounds way small. the 43 trim is way off. also the 2.25 down pipe is an indication, good for a 4 banger. yes the .63 a/r would spool quickly, on a honda. youd prolly boost at idle. my understanding is you can compensate; large turbo= lower A/R VS small turbo = larger A/R.
having that small of a turbo would run hot and run out of steam quickly. apparently boost later in the RPM also helps from throwing rods. maybe something to consider. a larger turbo will be more efficient and less of a bottleneck before boost comes on.
STS uses a 62mm (62trim) and its enough to blow stock engine and has virtually no lag. its a proven setup
people say that the cummins Holset hx35 turbos are too small and they are 56mm/58mm. although ive seen 350 sbc push out over 500hp and 4.6 stangs run 11 1/4s with them so IDK. going from 56mm to 61mm is not much of a difference IMO.
the hx40 would be a good choice as they flow a little better and some have the t4 flange, they can be found on 8.3 cummins. this is what im looking for.
i am no expert, maybe youd have better luck at the turboforums.com
remember thier are a lot more costs then just the turbo.
good luck on the build, need more turbo builds!!!!
I ended up getting a WH1c from a cummins. Yes, planning on a rear mount setup, or in the bay with taking the exhaust feom the y back into the bay and mount the turbo where its sits in a cummins. If i go that route i wont have to worry about oil pump. Just not sure everything will fit.
Either way since i still have all four cats, i think they slow the exhaust down enouph not to overspin or overwork the WH1c.
Still have a lot or research to do....what size injectors, bigger fuel pump, and if i can run the Mass Airflow sensor or have to go another route. Will see.
the whc1 is a like a small hx35. i think its a 54mm ish turbo. at least it will spool quick it should make no more then 300-350 max rwhp by my questimates. i think thats 33lb injector terriitory. like off a 2011 mustang. the newer f150 can do hp that on a stock pump.
i would at least remove the rear cats. a wastegate s job is to control the spin of the turbo.
the stock maf is fine.
i hope you can weld.....and have a fatty wallet and a compentant tuner
