supercharger
Old Oct 15, 2011 | 08:59 PM
TJScrew's Avatar
supercharger
I'm looking for a complete supercharger kit used. for my 2001 5.4 SC Don't have alot of time to shop for parts . But I don't want to put a ton of money in this truck either.
Old Oct 15, 2011 | 11:08 PM
Veteran: Army
so I guess you probably aren't going to have a supercharger then
Old Oct 16, 2011 | 05:51 AM
TJScrew's Avatar
I've seen kits on here for $1500 and I've seen them on here for $5000 . Thats why I'm on here is to try to determine if i can spend $1500 instead of $5000
Old Oct 16, 2011 | 07:11 AM
phil6608's Avatar
Simple answer,,,,NO. lol
But you will most likely need about 3K At least, to do it right!
Old Oct 16, 2011 | 07:32 AM
cobramarty's Avatar
You can find a 'kit' for a grand but it won't be turnkey or complete. THere will still be other things you will need. I bought a takeoff for a grand but will spend another grand to get it up and going.
Old Oct 16, 2011 | 09:18 AM
phil6608's Avatar
If your talking about a Lightning blower setup?
For 2K including a custom tune? That's a great deal!!!!
Old Oct 16, 2011 | 09:26 AM
cobramarty's Avatar
Non-lightning, and probably non-intercooled.
For vortech, procharger, powerdyne you can do it for 2k. I will be very close, always nickle and dime stuff.
Old Oct 16, 2011 | 10:06 AM
TJScrew's Avatar
2 or 3 Grand I can do . It's still not 5 . I need couple other questions answered like what do i need for a wiring harness and a tune . I don't need anything crazy just a pretty stock lighting set up, The truck already has an edge programmer will that help ??
Old Oct 16, 2011 | 10:24 AM
phil6608's Avatar
So what are you talking about you are setting up for 2K?
Old Oct 16, 2011 | 10:30 AM
phil6608's Avatar
You can use your stock wire-harness with some modifications. (You would need to ask someone who has done that for how to do it)
Easiest way is to use a stock L wire harness.
If your edge tuner is capable of having a custom tune put on it and you know a tuner that can give you a tune for it ,it would work.
Old Oct 16, 2011 | 10:36 AM
cobramarty's Avatar
Powerdyne S/C, brackets, pulleys, 90mm Lightning MAF, some tubing and connectors, + misc. stuff.
Added 255L fuel pump, 36lb injectors, spark plugs, dyno tune, misc. nuts/bolts and silicone tubing/clamps.
Additional I got but don't really need- new fuel filter, fuel level sender, 160* thermostat, underdrive pulleys, new K+N filter, A/F gauge, boost gauge and steering column mount, Sniper/Delta Force Commando programming software.
Old Oct 16, 2011 | 10:40 AM
Veteran: Army
since no one can tune that POS device for you once you're supercharged you're pretty much starting from scratch
pay close attention to those who are going to spend a fortune just to find out it's substandard and they need to spend more (many times at the cost of an engine)
Old Oct 16, 2011 | 10:56 AM
cobramarty's Avatar
What POS device that can't be tuned? Lightning supercharger?
Old Oct 16, 2011 | 11:37 AM
phil6608's Avatar
I think hes referring to the edge programmer!
Old Oct 16, 2011 | 11:41 AM
phil6608's Avatar
160* thermostat is pretty low! You sure you want to go with that?
Dose your under-drive pulley kit include a crank pulley?
If so,you cant use that with that blower.
