Cheap Ebay Twin Turbo set up
Old Sep 9, 2011 | 04:20 PM
  #46
IntRiniTy's Avatar
Lightbulb
Originally Posted by luckythirteen13
there is so much bad info on this thread i cant fix it all. im at work, not even supposed to be on this site.
anyways, i dont want to call anyone out so i wont....the the few things i will say are:
intercoolers dont cause lag
bov is for venting boost air when your off the throttle
wg controls boost pressure by venting exhaust pressure
those filter sandwiches are fine for pressure gauges but dont flow enough to feed a turbo
i have never sucked up water with my rear mount
one oil pump will be fine for twins, no one runs two scavenger pumps
stock pump + bap will be plenty for 400rwhp
run an intercooler, youll get better gains and decrease the risk of detonation
im sure there is more but thats what i got after quickly skimming the thread.
PLEASE NOBODY BE OFFENDED, IM NOT TRYING TO INSULT ANYONE
go to www.theturboforums.com and READ READ READ!
my f150 has a 70mm rear mount turbo and my mustang has twin 57mm turbos so i know what im talking about. fab'd both kits from scratch myself
none taken personally, i know squat about turbos. the input is appreciated. its nice to have someone that actually HAS a turbo setup
couple things i dont get.... hey im a noob
wouldnt extra piping cause more lag??? i quess its not noticable
i got the part where the BOV works of vacuum, not positive pressure
the sandwhich solution i was just throwing out there, although the one claims to be for turbos. i take your word for it. the fittings are large and the oil is getting pumped through ther. just as easy to tap the pan i quess
i read somewhere it had happened someone with the water getting sucked up, glad to hear it didnt happen to you.
so your are you running a I/C on your f150???
the scavanger pump, would you have a 't' fitting on the pump or run the one turbo into the other in series??????
sorry for so many q's:o
Old Sep 9, 2011 | 05:06 PM
  #47
luckythirteen13's Avatar
the extra piping makes little to no difference, a couple hundred rpm at best. look at any professional car running a turbo. the turbo will be mounted all the way at the front bumper, air is then pumped from the turbo back into the car where the intercooler is mounted in the location of the passenger seat and then it goes back through the firewall and to the motor. they run tons of piping too. the turbo is spinning 100,000rpm or more, its pumping a lot of air very quickly.
if the sandwich your looking at has large feed holes it may work, most arent designed for that, plus i think, I THINK, that oil is pre filter but dont hold me to it.
yes i am running an ic on my f150
yes, t the oil line coming from the turbos to the pump. you should run a .5" line from the turbos to the pump. or if your using AN lines, -10 hose and fittings. -8 will work but with twins id go -10 at the least between the t fitting and the pump
no reason to tap the pan, i get my oil from the factory oil pressure sending unit, just put a t on that. and then i run the oil from the pump back up to the valve cover.
and you can pump boost over your maf all day long, wont do anything to it. it has no idea. you just need to tune for it.
here is my build....not totally up to date witht he photos, i changed the air meter, no photos of that http://www.theturboforums.com/smf/in...topic=146119.0
here is another thread with a great rear mount build http://www.theturboforums.com/smf/in...topic=142130.0
Old Sep 9, 2011 | 10:33 PM
  #48
IntRiniTy's Avatar
thanks for clearing some of the slop up.
nice links too...
Old Nov 15, 2011 | 09:58 PM
  #49
IntRiniTy's Avatar
Wink
255 pump
http://www.fuel-pumps.net/tu270hp.html
Old Nov 16, 2011 | 02:46 AM
  #50
phil6608's Avatar
This is probably all you need if ya want to save some money.
http://treperformance.com/i-6321439-...2004-2007.html
Old Nov 16, 2011 | 10:04 AM
  #51
IntRiniTy's Avatar
what are your guys opinion on running a separate oil system for the turbos?????
1#oil wont blow past seals when engine is turned off, no valve or timer needed
2#wont coke/destroy/breakdown engine oil as fast or add extra containments/fragments,especially if turbos fail.
3#can use oil specific to the turbos, ie viscosity etc
4#engine oil wont heat up as fast/much
i was thinkin maybe x2 catch tanks
http://www.ebay.com/itm/Civic-750ml-...ht_5295wt_1392
then a oil/tranny cooler
universal-transmission-cooler
http://www.ebay.com/itm/TCI-820500-U...ht_2141wt_1159
and possible a filter
http://www.ebay.com/itm/Trans-Dapt-P...ht_1463wt_1159
Old Nov 16, 2011 | 01:35 PM
  #52
IntRiniTy's Avatar
turbo for dummies article---->
http://www.custom-car.us/turbo/default.aspx
Old Nov 16, 2011 | 01:50 PM
  #53
Nice!
Old Nov 16, 2011 | 04:42 PM
  #54
completely unnecessary. a lot of people have talked about it on the turbo forums but ive only seen it done once.
i have a $10 check valve that keeps my turbo oil seals safe so much cheaper then a stand alone system.
the oil doesnt pick up contaminants from the turbo. the oil only touches the very center of the shaft and is no where near the exhaust. the only contaminants youll get will be from the motor and you have to change that oil at the same rate with or without the turbo so no reason to separate the system on that account.
the turbo doesnt need special oil, its just a spinning shaft, there is no side load. its not like a motor that relies on hydraulic pressure to keep the parts from rubbing on each other.
there is a reason your engine has a cooling system.....to keep the engine and its oil cool. even with my turbo my truck runs at 194* all day long. i cant say for all remote kits but on mine, i run copper line feeding the turbo and then copper from the pump back to the motor so all that copper line acts as a cooler. many people have posted about running a cooler before the turbo on remote kits and the answer is the same every time, absolutely no reason
when the oil pump is used as a scavenger to just send the oil back to the motor, if the pump fails, oil gets pushed into the turbo and you will know its happening because white smoke will pure from the exhaust. you simply take the turbo off, clean it out, reinstall and your good to run. nothing is damaged. there are no actual oil seals in a turbo. the oil is just sprayed in a way that it stays in the center as long as you dont force in too much oil (thats why you run a restrictor)
if the pump is used in a closed system, if it fails, the turbo is starved of oil and the turbo is ruined. there will be no way of knowing the pump died because there will be no smoke.
Old Nov 20, 2011 | 08:19 PM
  #55
IntRiniTy's Avatar
thanks for the details lucky. very informational
now im scrappin the twin ebay turbos idea for a single 'holset' turbo from a cummins 5.9l diesel.
im eyeing at the hx35 maybe the hx40.
the dsm/supra guys run them and get 500-600hp. should spool quick as well. i assume making 500hp in a 4cyl needs to move about the same air as a 8cyl.
-Hy35, flows approx 57 lbs/min
-Hx35, flows approx 60.85 lbs/min
-He351cw (Spools faster than the hx35, but makes the same power) flows approx 60.85 lbs/min
-Hx40, flows approx 70.10 lbs/min
can any1 shed some light on this
the turbo has a a t3/t4 flange and is very reliable
running the IC piping looks like the trickiest part
for now im planning on running 39 lb injectors with stock pump
my goal is not to run over 4-6 psi/350rwhp. so 400-450 crank. or when ever i run out of fuel with stock pump.....
ill run some sort of BAP and turn up the boost when i can afford a beefed up tranny(4r75e) and HD tc. im running the 4r70 and 4.6 stall which already is higher
im hoping to run stock WG and lower boost somehow? or run a external gate and maybe a boost controller
still undecided wither to have oil drain to filler cap, valve cover, oil pan or maybe oil drain plug
new price list
JY holset hx35 turbo $250
used 39/42 lb injectors $160
ebay IC + piping $140
shurflo oil pump $120
t/3 flange, vband flange, t fittings $50
oil feed + drain + fittings $50
ebay bov + flange $30
aem wideband $ 165
boost gauge $40
pillar pod $ 40
tune $400
i read a article where they installed sts turbo on a 5.3 gmc and gained 80whp with NO TUNE w STOCK injectors running at 4.75psi/.25bar. they said the A/F was safe
apparently the buick grand national 3.8 turbo didnt use a BOV
i dont get how the hx35 turbo runs 22-35psi on a 5.9 L diesel but people say its small for a 4cyl gas????
im thinking about trying using the stock plugs. running low boost .25 bar and i have HO coils. or just use stock lightning plugs
Old Nov 20, 2011 | 09:37 PM
  #56
Veteran: Army
if you've got a single 255lph pump you'll be fine, if not, get one from a stock 5.4 truck your body style
Old Nov 20, 2011 | 10:00 PM
  #57
IntRiniTy's Avatar
so 05 3v come wtih 255?????
Those booster pumps arent that pricey and prolly easier then dropping the tank.
i was also considering those inline booster pumps like the t-rex. i was thinking sum kind of mod to hook it up through where the fuel filter is. like a loop with pump and filter then back if that makes any scense. if i drop the tank might as well get that 255 pump that drops in that you mentioned.
good website--> http://www.junkyardturbos.com/turbocharger-systems.php
so with FI i should plug the PCV right???? and run a breather???
i was going to run barb fittings for the oil lines. maybe just thread the return right into the oil drain plug hole as the return.
1/8 to turbo, 1/4 to pump then 3/8 lines(same as pump) to the return
may or may not restrictor
i still need to find those valves for the oil pressure on the inlet side
my autostart kit MIGHT have a turbo timer function, i have to look into it
i think i can utilize my stock k/n filter and DRYCHARGER with the stock housing using a 4'' to 5'' coupler like im already using. ill have to move the MAF and make custom housing using like a 4'' pipe from TB. hopefully that big enough so i dont max out the maf.
i found a local holset for 200 or best offer
after the turbo on the hot side they have a v-band turn down. i might just use that and keep it simple
Old Nov 22, 2011 | 11:10 AM
  #58
is it t3 or t4? its not both. turbos can be t3/t4 but that means the exhaust is a t3 housing and the compressor side is t4
you cant lower the boost pressure below the spring pressure. you would have to either change springs or if its not able to be changed, change the whole wg
i went with the filler cap because if i ever decide to remove the turbo, i can just buy a new oil cap and its back to stock. i wouldnt try to run the oil to the drain plug. if your oil pump isnt designed to stop backwards flow, as soon as you turn the oil pump off, the oil from the pan would force itself past the pump and into your turbo. plus the oil pump has to work harder because its constantly fighting the oil in the pain
new price list
ebay IC + piping $140be prepared to spend more then that. i have about $300 in ic piping alone on my truck
t/3 flange, vband flange, t fittings $50 a good v-band will set you back $30 at least
oil feed + drain + fittings $50this estimation is too low
aem wideband $ 165waste of money unless your the one doing the tuning
boost gauge $40
pillar pod $ 40http://www.ebay.com/itm/Universal-52...ht_5402wt_1141 this is cheap and i think im going to get it. it would be pretty discrete mounted all the way up in the corner of the window while still being at eye level
tune $400
apparently the buick grand national 3.8 turbo didnt use a BOV neither do diesels
i dont get how the hx35 turbo runs 22-35psi on a 5.9 L diesel but people say its small for a 4cyl gas????gas and diesel are total different fuel. you cant compare apples to oranges. comparing gas to diesel is like comparing apples to mustard.....not even close. it takes more fuel to make power with gas. my buddy used to have an 05 f250. the turbo on that was the same size as just one of the turbos on my mustang.
im thinking about trying using the stock plugs. running low boost .25 bar and i have HO coils. or just use stock lightning plugs go one range colder and gap to 32, stock coils will be fine
be prepared to spend more then you estimated. hose fittings, nuts and bolts will nickel and dime to to death
Old Nov 22, 2011 | 01:18 PM
  #59
just thought id post a few pics since these are new and how it sits now is different from when i posted my build thread both on f150forum and theturboforum
this is the breather for the crank case. the thing next to it is an oil/air separator. does a good job of keeping the smell of oil from being noticeable and also stops fine oil particles from escaping with the air
you can see how the one hose coming from the breather splits and is hooked to both valve covers
here you can see the mass air meter i run. you can also see the bov (the purple thing)
.......and just for fun
Old Nov 23, 2011 | 02:37 PM
  #60
jose_bigred's Avatar
I might "MAN UP' and start piecing parts for a turbo set up on my 4.6
Ima ask alot of questions! lol
Oh and good work guys! Now i need motivation!!!
