To Supercharge or not ?
Old Aug 29, 2011 | 04:45 PM
Rodneys's Avatar
I been thinking about how to get more HP and TQ....I tow a 8000 lb camper 6 or 8 times a year. Most of the time it's alright except the long mountains following my buddies with there desiels . My truck has 90,000 would it need rebuilt first and what is a good supercharger kit I could get,,since it would be cheaper that a new truck,,,thanks
Old Aug 29, 2011 | 08:51 PM
Rambo274's Avatar
At 90000 I think it would be a good Idea to have a basic rebuild done if your not going to run high boost levels. If your going to run high boost levels ,forged internals is a must.
Old Aug 29, 2011 | 09:29 PM
Veteran: Army
go for a roots type or waste gated centrufigal, NOT a twin screw
Old Aug 29, 2011 | 09:42 PM
Rodneys's Avatar
Ok,,Thanks alot,,,I probably need the cam phaser job also,,you think ?
Old Aug 30, 2011 | 10:56 AM
WhippleSCREW's Avatar
I Have a whipple on my truck with 4.88 gears, and air bags. The thing tows like a beast! my boat is about 8,000lbs when loaded with gear . I run 75-80 at 1/4 throttle. I havent towed through the mountains yet, Next June we are headed to Lake Powell so i will put it to the test then.......
The tune that whipple uses is horrible i would sugest getting a custom tune if you go that route.
Old Aug 30, 2011 | 01:24 PM
Rodneys's Avatar
Did you do a rebuild WhippleScrew ?
Old Aug 30, 2011 | 01:39 PM
BROTHERDAVE's Avatar
25 Year Member
I say no. 7 to 8 year old truck , save the money
what rear gears do you have? going to a 4.10 would help. look at tow ratings and changing the rear gears get the biggest results.
had a centrifugal and at 2500 to 3000 rpm it did nothing, towed a 5000 pound trailer and i could not really see a difference.
to me a boat pulls different than a TT, the TT has the aero dynamics of a brick , the boat cuts the air so much better.
if you did rebuild the motor, you have to know the trans is right behind it. figure in a rebuilt trans, rebuilt motor, cost of SC and cost of installation and tune, you end up with a 8 year old truck that you put over 10k in that is still an 8 year old truck. at 7 to 8 years old realistically small things are going to start going wrong.
seriously work up a budget as to what it will all cost. if you have 10k to 12k cash and love the truck then that is up to you.
Old Aug 30, 2011 | 02:46 PM
sbchris's Avatar
I'd be a bit more worried about the cooling system and trans temp. Pulling high into the mountains will create a ton of heat. I know when I pull anything with a good amount of weight to 7K feet the truck gets really hot.
Old Aug 30, 2011 | 08:52 PM
Rodneys's Avatar
Greatly put,,,I'll keep it stock for now,,,Going up N.C. mts..Trans temp got to around 225 on my scan gauge for about 10 mins.
Old Aug 31, 2011 | 10:54 PM
Veteran: Army
my trans runs cooler on the highway once I added boost as it maintained OD on all the hills
