Need Boost!
Old Jul 1, 2011 | 10:37 PM
MJMoog34's Avatar
Need Boost!
Ok so im new to the whole power adders but i know how each works the question i have is i wanted more power in my 2000 XLT which has a 5.4l i want something that will be noticably quicker. Would love some help thanks!
Old Jul 1, 2011 | 11:26 PM
IR0NS1N's Avatar
Lightning swap.
Old Jul 2, 2011 | 11:34 AM
phil6608's Avatar
Originally Posted by IR0NS1N
Lightning swap.
X2
Old Jul 2, 2011 | 11:42 AM
Ford12508's Avatar
Lightning swap with 4V heads
Old Jul 2, 2011 | 01:33 PM
MJMoog34's Avatar
what is that gonna cost?? Like 4K?
Old Jul 2, 2011 | 02:25 PM
phil6608's Avatar
More then that if you try to put 4V heads on it.
You can to the intake assembly for less then that. Depends on where you get the parts and if you install it yourself.
Old Jul 2, 2011 | 03:29 PM
MJMoog34's Avatar
Ok well im pretty good with auto stuff and been redoing a 302 for my mustang. But how hard is it to put in an L swap without the 4V heads?
Old Jul 2, 2011 | 06:29 PM
phil6608's Avatar
It's a lot less work then building your 302.
You need to do an intake manifold swap. An L intake swaps right on your current motor.
You need one with the injectors and all the vacuum lines.
Then an heat exchanger,hoses ,pump. And some other parts,(nothing major.
You'll need a good custom tune for the computer also.
Parts you need.
http://www.madenterprise.com/scparts.htm
Most of them you can get used and save some money.
Phil
Old Jul 2, 2011 | 08:19 PM
Windsor's Avatar
Since Lightnings were 2v motors, a whole lot easier.
Old Jul 2, 2011 | 09:17 PM
MJMoog34's Avatar
Ok! well guess im going to have to start looking for these parts!
Old Jul 2, 2011 | 09:55 PM
phil6608's Avatar
Here's a couple places that are good for finding the parts you need.
http://www.nloc.net/classifieds/showcat.php?cat=7
http://www.lightningrodder.com/forum...splay.php?f=23
Also ebay.
I used all new parts from the other link I posted (had a tuner already.) And it only cost me about 35 hundred with install! Well, my original setup anyway.
Phil
Old Jul 2, 2011 | 10:01 PM
MJMoog34's Avatar
Well ok im kinda dumb when it comes to superchargers but i saw a guy selling the supercharger with air intake and i think its manifold it sits on? for like $600 and it has 40k on it. is that a good price?
Old Jul 3, 2011 | 12:30 AM
phil6608's Avatar
Well just the supercharger goes for around $300 used. And Ive seen intake manifolds go for $300 or less.
If it has any-other parts that go with it it's not a bad price. Depends on what shape it's in.
I've also seen the hole intake with injectors,vacuum lines from the manifold up go on ebay for $650. to 800.
Old Jul 3, 2011 | 01:09 AM
MJMoog34's Avatar
is there a certain brand of supercharger i should really keep my eye out for? Cuz i heard of whipple and i think eaton?
Old Jul 3, 2011 | 06:54 AM
phil6608's Avatar
The Eaton came stock on the Lightning.
A Whipple or Kenne Bell would be a very expensive upgrade. They make both to fit on the L intake-manifold but most need a built block to run the kind of power they make.
I run a 2.3 KB on my truck.
