To GEAR or Not To GEAR!
Old Apr 27, 2011 | 02:26 PM
twinskrewd's Avatar
You would like the 4.11 Yukons. You can get them from Wayne at www.diffsonly.com with a complete rebuild kit for the rear also made by Yukon with Timken bearings for a good price. I paid $310 shipped back in Nov. You will have to email him for the price. Prices on the web page are suggested retail.
Old Apr 27, 2011 | 02:34 PM
Brain_Mach1's Avatar
It is simple algebra. Switching from 3.55 to 3.73 is only a 5% mechanical advantage.
3.55 to 4.10 is 15%
3.55 to 4.30 is 21%
3.55 to 4.56 is 28%
If you think the cost of parts and install is worth a 5% increase, go for it.
Old Apr 27, 2011 | 03:22 PM
Jetpilot2's Avatar
3.55 to 4.10 is 15%
3.55 to 4.30 is 21%
3.55 to 4.56 is 28%
Old Apr 27, 2011 | 03:23 PM
Jetpilot2's Avatar
THANKS!
I'll give him try.
Old Apr 27, 2011 | 03:53 PM
IR0NS1N's Avatar
Once I go to 32.8" tall 305/45/22s I plan to do 4.30 gears. More then a 4.10 for the weight but I think 4.56 may be just to many RPMs. Although I do 90% city driving.
Old Apr 27, 2011 | 07:57 PM
dilloncawthon's Avatar
yeah if you're 2wd i would definitely go 4.30s.
Old Apr 28, 2011 | 07:08 AM
FATHERFORD's Avatar
Originally Posted by Crash!
I hear where you are all coming from. It's just that we have gone from 17 second E.T.s to 10s, and we have used the 3.55s. I ran 12s with 3.55s. Is it worth a 5% advantage? No. But if you order... It is a good all around gear.
You have to figure in our trucks weigh nearly 1k lbs more then the 97-03 trucks.
You are talking 600-700rwhp+ to get 10's in our trucks.
Old Apr 28, 2011 | 11:38 AM
IR0NS1N's Avatar
I am still heavily considering 4.56 gears. If I had saleen wheels there would be no doubt on 4.56. Rims I am getting are 40lbs and tires are 40lbs so alot but less then saleen.
Old Apr 28, 2011 | 11:54 AM
FATHERFORD's Avatar
Do you ever go to the track?
4.11 gears with 28" slicks(around 29" at 100mph or so) just about have me bumping rev limiter at the end of the track.
If you don't think you will ever run into that problem, and mostly drive city, get 4.56's... They will make the truck fun as hell to drive stop light to stop light.
Old Apr 28, 2011 | 12:26 PM
IR0NS1N's Avatar
I haven't been to the track in a good while. If I do it'll be on street tires at this point. I can't see spending 500 drag radials right now. Maybe with a better bottom end and reving to 65-7000rpm I will. My plans for my truck are changing it seems
Old Apr 29, 2011 | 07:40 AM
phil6608's Avatar
Originally Posted by Jetpilot2
My tires are 305/40/23 (32.6") and YES!, they weigh a ton!!
I like the info. here.
I run the same size wheel and tire combo in the summer and 4.11 are perfect.
I also run my stock 16" wheel and tires in the winter and I like it then too.
Old Apr 29, 2011 | 07:59 AM
twinskrewd's Avatar
Hey FatherFord what is your rev limiter set at? I am running 26' drag tires and now with 4.11's I'm sure I'm gonna hit it. Time to sell these and get some taller tires.
Old Apr 29, 2011 | 08:40 AM
FATHERFORD's Avatar
5600rpm..
with bald 26" m/t's I was hitting the rev limited right before the trap with the rev limiter set at 5400. Ran a best of a 12.7@100mph at HRP with that setup. Bumping the limiter hurt my mph and time.
The 28" m/t slicks are the ticket.. they grow about to 29" by 100mph also so it gives you a little more room. So far my best was a 12.5@107mph at Sealy(Hennessey's Race track). That's when I noticed my tranny kinda slipping between gears.
I haven't ran my truck since the 12.5 run, but now I have a new built transmission and my "street" tune is about 40rwhp more, and my race tune is 80rwhp. So I'm hoping with good air this fall to hit an high 11...
Old Apr 29, 2011 | 12:13 PM
IR0NS1N's Avatar
What type of M/T and where are you getting your M/T slicks at?
I see a 305/45/18 in the street radial II
Old Apr 29, 2011 | 01:50 PM
Huitt24's Avatar
I think he meant his Hooser Slicks. At least that is what I saw at his house. They are a true slick not a drag radial.
I am running 4.30's on the street with a 305/40/22 which is 31.5" tall and they do alright. Been thinking about swapping them out for 3.73 for a little better top end.
