Need help to identify whipple bracket.
At first I thought was the fuse box relocation bracket even though it didn't look correct. My 07 upgrade kit came today with the correct looking bracket. So now I'm up in the air again. I've read the instructions, but just can't seem to find where it's used.
Thx in advance.
Thx in advance.
That is the fuse box bracket that I used on my 04. Remove the forward bolt of the coolant reservoir and slide the bracket under the reservoir and reinstall bolt. Pull the fuse box that is just forward of the reservoir off of the fender, mine was held on with plastic plugs. Then bolt it on the bracket. If you need any other info let me know, I installed mine about 2 months ago. Since I don't have the 07 does the new kit come with a different bracket for the fuse box? If so you can just pitch that bracket.
Tim
Tim
