Wheel hop and traction bars with the Whipple
Old Mar 22, 2011 | 07:32 PM
sbchris's Avatar
Here is what I went with installed on the truck, the Cognito econo made to work for a chevy.
Rides great, a bit stiffer but I am really happy now when I mash the pedal.
Old Mar 22, 2011 | 08:13 PM
str8t six's Avatar
which kit did you go with? they have a bunch listed on their site.
Old Mar 22, 2011 | 08:44 PM
sbchris's Avatar
I went with the econo 60" bars.
Old Mar 22, 2011 | 09:18 PM
str8t six's Avatar
this one?
http://www.cognitomotorsports.com/pr...n_Bar_Kit.html
how was the install? does it just use 2 bolts for the front mount and weld on the axle tubes?
Old Mar 23, 2011 | 01:48 AM
sbchris's Avatar
Yea they only sell three kits, though their site makes it look like they sell 10.
I went with the econo 60" and bought them from alligator diesel.
I had my rock crawler shop weld both sides (frame/axle) of the kit and said screw messing around with the bolts. I was going to weld the axle tube tabs to the bottom of the u-bolt mounting plate but I'm running the HD setup and the mounting plate is cast. Not going to work. I set them a slight angle to the inside of the plate and so far so good. I really noticed on hard shifts/acceleration the truck doesn't rear steer anymore.
Old Mar 23, 2011 | 11:10 AM
str8t six's Avatar
Did they affect articulation at all? how is the construction on them? they seem solid?
im really thinking about getting these since they are about 100 cheaper than anyone elses bars.
Old Mar 23, 2011 | 01:05 PM
sbchris's Avatar
They weight a good amount and are pretty solid, all the duramax guys run these for sled pulling events. They have a poly-euro mount on the frame side and a rod-end on the axle. If you are not afraid to fab them to work they should work perfect.
I'm not into rock crawling but I have not noticed anything weird on angled slopes.
Old Mar 23, 2011 | 03:05 PM
str8t six's Avatar
thanks
Old Mar 28, 2011 | 05:05 PM
RedJackedUP's Avatar
i want some
