2.2 liter kenne bell
I dont know much about these things and would appreciate some input. I put a 5.4 in my mustang..i have 11.1 compression and cams. I aquired a kenne bell and now I can not use it because of the build I did. I guess I would like to know if there is a market and what it is worth. (it is the one that uses the factory 5.4 intake.
Thanks,
Sam
Thanks,
Sam
Thanks,
Sam
Thanks,
Sam
Thanks,
Sam
Thanks,
Sam
Phil
Thanks,
Sam
Thanks,
Sam
it's a POS setup, if you can get anything for it then you got lucky
I cant use it on my car because it is has too high compression. Even with a tune I have to run 93+ to keep from detonating.
I know 11:1 is pretty high but you should be able to back the timing up enough to run 6 or 8#s of boost.
I had that kit on my 5.4 and it's not a great kit.
It's ok for 6 or 8 pounds but you need to run a water/meth kit with it.
Phil
Phil
