New supporting mods for my Supercharged F-150
Old Oct 25, 2010 | 10:04 PM
FATHERFORD's Avatar
Had to make it supercharger related
Called Darrin Burch at BC Automotive and got this nice little package in the mail.
Purchased a custom valve body kit, to which I informed him I want it to bark the tires just idling along.
I also purchased the tail shaft lube mod kit. I typically go well over 120mph so I felt this modification was needed.
To help with the cooling I purchased a deep sump aluminum pan. Also for it just looking cool.
Further talking with him we decided it would be best I installed the Spiral lock kit since I'm pushing, and will once I put my built engine in, 6000rpm and over.
Hope to do the install this weekend.
Old Oct 26, 2010 | 12:05 AM
bankrpt's Avatar
nice what does a spiral lock do? and im assuming the tail shaft lube mod kit routes trans fluid to the tail shaft to keep it cool? pretty soon you'll need a cage in the truck lol keep up the good work
Old Oct 26, 2010 | 12:45 AM
weazel's Avatar
Registered User
thats what i need is a valve body!
Old Oct 26, 2010 | 01:40 AM
Faster150's Avatar
looks good!
Old Oct 26, 2010 | 06:45 AM
FATHERFORD's Avatar
The Spiral Lock(the black circle in the bottom left of the pictures) replaces the factory lock which is known to start working it's way loose after repeated 6000rpm uses. I really don't need it right now, and it requires the transmission to be pulled to install. I shift at 5500-5600, and RARELY pull to 6000rpm. I'll be installing that when I put my new engine in as I plan to be taking it to 7000rpm+
As for the tail shaft lube mod, the 4R70/4R75 transmissions has a "flaw" with eating up the bushings in the extension/tail housing. Especially when running 4.10 and higher gears(with factory size or smaller tires), and high speed driving. It is my understanding that the lubrication technique function in the tailshaft housing is more of a "splash" instead of fed oil. This mod comes in and feeds oil to the back of the tail shaft, keeping the bearings lubricated and cooled.
Old Oct 26, 2010 | 07:54 AM
bankrpt's Avatar
Nice
Old Oct 26, 2010 | 09:01 AM
ONELOWF's Avatar
Good stuff .... longer life for the trans.
Old Oct 26, 2010 | 09:29 AM
FATHERFORD's Avatar
What really motivated for me to do this is the 1-2 shift wasn't quit shifting quick/hard enough. I want it to bark my slicks while going down a sticky track, while right now with my slicks I noticed it wasn't shifting fast enough and in a round about way slipping.
Old Oct 26, 2010 | 09:38 AM
Windsor's Avatar
Nice. You're going to love the valve body.
Old Oct 26, 2010 | 01:21 PM
Veteran: Army
Old Oct 27, 2010 | 08:32 PM
weazel's Avatar
Registered User
does the tune need to be changed with a valve body? and will it work with a trans go shift kit? im not an expert on trans..
Old Oct 27, 2010 | 10:55 PM
Windsor's Avatar
If the pressures are increased in the tune, then it probably would need to be toned down. But some like a harsh shift. I believe anything that came with your Trans-Go kit will be replaced with the valve body.
Old Oct 28, 2010 | 06:24 AM
FATHERFORD's Avatar
I was told the pressure doesn't have to be toned down if I liked where it's at.
You would replace your trans go setup with this entire valve body.
Are you not happy with your trans-go setup?
Old Oct 28, 2010 | 10:05 AM
Windsor's Avatar
If you're only going to put the one spring in the 1-2 accumulator, that shift at light throttle and slow speeds can be a bit harsh. You just won't get a good, firm WOT 1-2 shift if you install both springs. It just depends on how aggressive your tuner got with transmission functions. But yeah, it can't hurt anything and to each his own on the amount of shift firmness you desire.
Old Oct 28, 2010 | 06:49 PM
weazel's Avatar
Registered User
No i like it, was just curios. I do plan to try and start my short block build soon, so just looking for in the future.
