is this worth it?
is this worth it?
http://dallas.craigslist.org/dal/pts/1782616731.html
for 700
my plans are to put it on as is plus e fans for now and then upgrade to a 9psi pulley, 90mm MAF, 42lb injectors, 190lph fuel pump (if that will work), and a custom tune then maybe I/C.
I have read about a bypass valve what exactly is that and where does it go?
and can I get some pics of peoples intalls, since the kit is missing the bracket to relocate the power steering resivoir
anything else I missed would be helpful
for 700
Here's some info on the bypass valve: http://www.928motorsports.com/parts/blowoffvalve.php
Look around the 928 site for the most info you will find on the Powerdyne.
I have the original instructions from the Ford Motorsport Powerdyne kit which may be helpful to you. Post a fax # and I will send them. That way you can get a better idea what is / is not included in the kit and how it goes together.
