Bigger injectors in an 2004
Old Nov 22, 2009 | 11:35 PM
KyleB's Avatar
I'm finally getting around to upping the boost on my truck and getting a real tune in it. My question is I pulled out my stock injectors and they look different from the 42lb Ford Racing injectors I have. Does someone make some kind of adapter for these? Or is there a different injector I need to be using?
Any feedback is welcome.
Old Nov 22, 2009 | 11:46 PM
Paralyzer's Avatar
how much boost are you going to run? are you sure your current injectors are 42s and not 39s? didnt know they even made a 42 for the 04+
Old Nov 23, 2009 | 12:57 AM
KyleB's Avatar
Maybe I didn't make that clear enough... My stock injectors are not 42's I have a set of 42's that I want to put in but they seam to hook up different than the stock ones.
Old Nov 23, 2009 | 01:44 AM
Paralyzer's Avatar
those 42s you have are for a 03 or older. you need some of these http://www.fordracingparts.com/parts...tKeyField=5941 what setup are you running?
Old Nov 23, 2009 | 09:00 AM
KyleB's Avatar
I have roushcharger that I'm putting the +2lbs lower pulley on... I put a walbro 255 fuel pump in the truck and have a kenne bell boost a pump. So now it's time to up the injectors and get the brick tuned
Old Nov 23, 2009 | 09:37 AM
05RedFX4's Avatar
Umm, the roush kit already has #39's, more than adequate for a +2 lb lower.
Old Nov 23, 2009 | 11:27 AM
KyleB's Avatar
I got the non I/C kit, no injectors
Old Nov 23, 2009 | 11:40 AM
05RedFX4's Avatar
Sorry, did not know that. Here try these
http://www.teamjdm.com/shop/product_...roducts_id=231
Old Nov 23, 2009 | 01:27 PM
Marc Carpenter's Avatar
I purchased a set of 39#er's from Roush for mine. Yes I am running a 2# lower with the non-IC'd Roush. Mike tuned mine on the dyno after the 39#er install and I am doing fine. If you don't want to go to Roush you can pick up a set of '03-'04 Cobra injectors from some place like Blue Oval Performance and use them. If Mike T is doing your tune then I suggest you buy a set of Roush's through him. There are a few suttle differences in the same size injectors if they are from different manfacturers.
Old Nov 23, 2009 | 04:15 PM
KyleB's Avatar
Marc, thanks... I'm curious, do you know what kind of power your truck made after being tuned?
Old Nov 23, 2009 | 04:52 PM
Dyno sheets are in my vehicle so off the top of my head I remember that we were in the mid 340's but the air fuels were too lean so by backing it off to the 11.80's -11.90's because its a daily driver , I am somewhere in the low to mid 330's. I am very happy with the results.
I did not install the SC for hot rodding purposes, I only wanted more power and torque for the 6000# vehicle. However it did manage to go 14.93 at the track one cool evening.
Old Nov 24, 2009 | 09:26 AM
KyleB's Avatar
Trading my 42s for some cobra injectors today... Hopefully I can have it tuned and ready to rock in a week!
