boost gauge
Old Nov 14, 2009 | 12:50 PM
datdude68's Avatar
boost gauge
I want to install a boost gauge on my truck how difficult is it and how would i go about doing it. Any help will be appreciated.
David
Old Nov 14, 2009 | 05:00 PM
weazel's Avatar
Registered User
David
what supercharger kit are you running?
Old Nov 15, 2009 | 05:59 PM
deton8r's Avatar
I'm planning the same thing for my Roush s/c Foose. I'm actually quite surprised the gauge wasn't part of the s/c package. Will that Saleen Boost/ACT pod work with a Roush? For $99 on eBay, that's a great deal but I don't want to buy something that won't work.
Plan B is to go with an Autometer boost gauge in a vent pod but I'm not sure where the best place to run the vacuum line through the firewall would be. I would use the vent on the right of the steering wheel if I go this route.
Comments/suggestions?
Old Nov 15, 2009 | 10:41 PM
datdude68's Avatar
Hey Weazel I have the Roush Supercharger
Old Nov 15, 2009 | 10:56 PM
derrick929's Avatar
David
Its pretty straight forward. Just "T" into any of the vac lines and run the hose through the firewall. EIther find a hole or drill one and put a rubber grommet in it. Right under the drivers side dash works great, can even get in there to drill a hole. There are already a few grommets there you can poke a small hole in and use one of them.
Put the gauge in the A-pillar pod and add a few more to go with it. It would be worthwhile to get a fuel pressure gauge while your at it. Or get one the the Aeroforce gauges, it pretty much does it all.
http://www.aeroforcetech.com/
Old Nov 16, 2009 | 11:19 PM
IR0NS1N's Avatar
I have an aeroforce guage but dont use it for boost. My whipple had a little port where I could plug in my boost guage (via vac line) and it works flawless. I use the Aeroforce for trans temp, fuel pressure, MAF readings etc. I also have a Wideband on too. If you look under the factory coolant tank you will see some wires already going through the firewall, I just stuck the vaccum through there.
Old Nov 18, 2009 | 02:03 AM
07harleyD's Avatar
Where is this port on the Whipple?? I just bought a 07 harley supercharged and I have no boost guage, its starting to bug me.
Old Nov 23, 2009 | 11:40 AM
KyleB's Avatar
On my roush kit, it can wired up for a boost gauge already... all i did was plug it in
Old Nov 23, 2009 | 04:41 PM
datdude68's Avatar
Where does the vaccume line connect to on the SC???
Old Dec 3, 2009 | 05:00 PM
datdude68's Avatar
help
Iron I just purchased an Aeroforce gauge and I have a few qeustions do I need sending units for the trans temp, fuel pressure and maf readings? Also what else does it show without using a sending unit?
Old Dec 3, 2009 | 05:08 PM
Veteran: Army
I know you need a kit for the fuel pressure, call lew and see what he says
