Magnacharger/AED question.. ???
Yeah I might look into that... so is this supercharger a mismatch for the lightning engine? It seems to run really well and what i've read about the AED superchargers it seems that they are very reliable... ??
But your right, with the lower compression pistons in a Lightning block he would make about 25hp less then with a N/A block.
Sorry for the lack of info- It actually already has the 42# injectors and MAF mod done. And the guy I bought it from had troyer tunes in it.. I am just going to leave it @ 8 PSI.. Now i'm not exactly sure what you guys mean about the low compression. I know the L engine has lower compression but why would that affect the M90 and how much extra strain is it putting on it?
like Derek said having your IAT sensor located in the Plenum is best. do you know if it is mounted there or in the intake??
Mike @ Troyers requested I move mine witch required me removing the S/C and drilling and tapping the hole.. not hard but mybe the old owner did not take this step. worth looking into
great idea on the power stroke guage
I still have my old IAT sensor in that location ill look into getting one. to help air temps I was looking to get a bigger coolant tank. Im still @ 5lb 6 on a cold day lol If needed I have the Magnacharger install instuctions in a pdf file good for the 4.6 or 5.4
