Turbo Question-I keep getting fault code P0106
Old Oct 18, 2009 | 09:17 PM
Rusty5.4's Avatar
Problem is fixed.
Old Oct 19, 2009 | 05:25 AM
Veteran: Army
hmmmm, where have I seen this before
#1 you started multiple threads...
#2 since everyone else has the same exact vehicle you have your lack of info really helps nail down the problem from the otherside of the internet...
Old Oct 19, 2009 | 06:07 PM
Rusty5.4's Avatar
I trying to get all the help I can.
Old Oct 20, 2009 | 05:32 AM
Veteran: Army
if you were seriously trying to get some help, you'd give us some information to work with and since we're on the other side of the internet, we have no idea as to what your setup is...
Old Oct 21, 2009 | 12:57 PM
eckomaninred's Avatar
My guess is check the blinker fluid. Do you have a 4.6? 5.4? What year? Turbo kit?
Old Oct 21, 2009 | 01:01 PM
P0106 - Barometric (BARO) Pressure Sensor Circuit Performance Baro sensor input to the PCM is monitored and is not within the calibrated value. Slow responding BARO sensor
Electrical circuit failure
Damaged BARO sensor
Damaged PCM
VREF voltage should be between 4.0 and 6.0 volts
PID reading is in frequency
