Fuel Pressure regulator Help 2003 F150
Old Sep 18, 2009 | 11:11 AM
Mission's Avatar
Exclamation Fuel Pressure regulator Help 2003 F150
Hello all,
I am looking for some advise /help with a fuel pressure issue on my 2003 King Ranch S/C 5.4L 2V with D1SC Procharger.
I recently had twin Walbro 255 installed in-tank cause the in-line kept burning out. I had the feed line upgraded to a -8 braided and now the fuel pressure is sitting around 60 - 70 PSI at idle. I figured the fuel pressure regulator must have given up, so I replaced it, but it is still the same.
I am hoping someone with the same year can let me know what they did to cure this issue. I believe the 99 - 03 all had the same press and clip style regulators and I cannot find anyone that makes an aftermarket, adjustable FPR for this application.
I have two options that I can see:
1) find some '98 rails and purchase an adjustable FPR to fit.
2) purchase an aftermarket kit with rails, regulator et al (Aeromotive 14118)
Before I spend the $900+ they want for the Aeromotive kit, has anyone found a better, easier solution to this?
Thanks,
Mission
Old Sep 18, 2009 | 01:43 PM
ONELOWF's Avatar
Are you using an fmu? If so, it is calibrated for 39 psi. I have never used an fmu, so I'm guessing here.........
Old Sep 18, 2009 | 03:11 PM
JMC's Avatar
JMC
25 Year Member
Check the vacuum source to the regulator. Apply vacuum to the regulator to see if it lowers the pressure.
Old Sep 19, 2009 | 12:51 AM
Mission's Avatar
ONELOWF,
Thanks, No, an FMU is a bandaid fix. A good tune replaces it.
JMC,
Thanks, I will check to ensure it is producing vacuum. Didn't make a difference when I removed it to test, so that is likely the issue.
Thanks guys,
Mission
Old Sep 19, 2009 | 04:27 PM
Mission's Avatar
So, I checked the vacuum line to the Fuel Pressure Regulator and it is a steady 17 inch HG. What else would be the issue of high fuel pressure?
Thanks...
Old Sep 19, 2009 | 04:33 PM
JMC's Avatar
JMC
25 Year Member
When you installed the duel fuel pumps did you kink the return line?
Regards
Jean Marc Chartier
Old Sep 19, 2009 | 04:47 PM
Mission's Avatar
Regards
Jean Marc Chartier
JMC,
Thanks, I didn't do the installation. I had a local Ford Racing mechanic do it. I will crawl under to take a look. I talked to him about the issue being the return line after the feed line being upgraded. He assures me the return line is big enough stock since it is a "trickle" back.
Wouldn't it stall if there wasn't enough back flow?
Thanks,
Mission
Old Sep 19, 2009 | 05:17 PM
Windsor's Avatar
Just a thought, since you already replaced the regulator. Are you sure your pressure gauge is accurate?
Old Sep 19, 2009 | 05:28 PM
Mission's Avatar
Thanks for the post.
Yeah, the fuel pressure guage is reading correctly. It also blows black smoke and runs crappy, so it is definitely running rich. It threw a code, but, of course I didn't write it down prior to reflashing the custom tune in hopes that would fix it. I am going to check the return line then take it for a run to see if I can get it to throw the code again.
Thanks,
Mission
Old Sep 19, 2009 | 07:01 PM
Mission's Avatar
Well, I crawled under and took this picture. It seems to be crimped in one spot of the line.
Think that may cause the issue?
Thanks,
Mission
Old Sep 21, 2009 | 12:21 AM
Blown F-150's Avatar
If that's on the return side, then yes it looks pretty flat and would be restricting the fuel getting back to the tank.
Old Oct 2, 2009 | 03:22 PM
Mission's Avatar
Well, after pulling the return line and running it, it is still at 70 PSI.
Old Oct 3, 2009 | 04:10 AM
JMC's Avatar
JMC
25 Year Member
Ask your installer which pump he used. A GSS340 pump is a 255 L/Hr high pressure pump.
Regards
Jean Marc Chartier
Old Oct 5, 2009 | 04:41 PM
Mission's Avatar
JMC,
It's the dual pump Walbro. I believe (don't quote me) it is the LFP-1198 kit. It is back in getting the return line replaced and I figured I might as well have the rails replaced with an adjustable regulator. I am getting plenty of pressure, so I believe the stock regulator is just not able to perform properly.
I am having it dyno'd immediately afterwards, so I will let you know how it goes.
