Compression test on my new lightning motor...help??
Old Jun 22, 2009 | 10:39 PM
20Screw01's Avatar
So I bought a used 2000 lightning motor and with the throttle wide open and oil pressure cold the test is coming back at 120-125 on all cylinders. What is stock cold and what the heck do I do to see if its just the rings?
Thanks Dave
Old Jun 23, 2009 | 08:05 AM
05RedFX4's Avatar
I don't know what the should have when they are new, but if your within 5 lbs on all cylinders and you have a low of 120, I would think your rings are in good shape.
I remember the old smog motors from the 70's only putting out 75-80 psi when they were new, so if you got 120 on a used L motor, get it put in already and go enjoy it.
If you were to have an engine buider build you two identical motors and have one blueprinted to run N/A and the other blueprinted for forced induction, the N/A motor will pull higher numbers on a compression check then the blown motor will.
Old Jun 23, 2009 | 12:13 PM
20Screw01's Avatar
Thanks Red, I hope your right! I just want to make sure before I run this thing. Anyone know what these put out on a compression test?
Old Jun 23, 2009 | 03:00 PM
CobraKit's Avatar
I will check Ford shop manual, but I would agree that 120 and variation you are seeing is not bad. When I rebuilt my engine, the high boost (14lbs on non L block) waisted the rings and the exhaust valve guides. Valves and cyclinder walls were fine.
Old Jun 23, 2009 | 03:10 PM
20Screw01's Avatar
That would be great if you could check for me Cobra! Just want to put my mind at ease.
Old Jun 23, 2009 | 07:36 PM
150xlt's Avatar
Those numbers sound about right to me
Old Jun 24, 2009 | 08:10 AM
CobraKit's Avatar
Forgot last night. Promise I will do tonight and post. Ford shop manual (actually Heim) is crap. Its hard as h... to find things.
Old Jun 24, 2009 | 07:18 PM
CobraKit's Avatar
Manual did not call out. Said 75 percent diffrence allowed between high and low. Add oil on low to see if it makes a diffrence. If it does rings, if not valves. Chart showed max pressure from 134 to 250 and low to 101.
Old Jun 24, 2009 | 09:31 PM
20Screw01's Avatar
Thanks Cobra! I dont know why I didnt think of testing my cobra but I went ahead and tested it (03 low compression motor) and it came back at 125-130 with 10k on the factory motor so i am going to run it!
