SUPERCHARGER FOR 4.6L 2004 n' UP
Old Oct 31, 2008 | 03:06 PM
07F150OAKLEY's Avatar
Exclamation SUPERCHARGER FOR 4.6L 2004 n' UP
I would greatly apreciate if someone could tell me what supercharger would fit on a 4.6 stock engine and a close shot on the price too!!!!!THNX
Old Oct 31, 2008 | 03:12 PM
FX4 Matt's Avatar
Registered User
There is none,... you should have got a 5.4
Old Oct 31, 2008 | 03:54 PM
Veteran: Army
go for a procharger. the '97-'03 will bolt right on up
Old Oct 31, 2008 | 04:16 PM
NoLongerJeepin's Avatar
Has anyone tried this?
Old Oct 31, 2008 | 05:09 PM
shaunakadub's Avatar
Is this true tarajerame?
I've done endless searches trying to find a charger that will work, and have never heard this one.
I was leaning more towards getting a universal STS turbo.
Old Oct 31, 2008 | 07:43 PM
josh34's Avatar
it might bolt up but you have no tuning option
Old Oct 31, 2008 | 10:52 PM
phil6608's Avatar
There's plenty of tuning options!!
Phil
Old Nov 1, 2008 | 03:24 AM
Veteran: Army
the new body style trucks with the 4.6 engine have the same engine as the '97-'03 trucks... (with the exception of a few fuel lines on a certain year, however with larger injectors no FMU is needed and avoids this issue all together) Allen Engineering bolted a eaton M90 kit onto an '05-'06? 4.6 truck and the fuel line for the FMU was the only thing that they needed to modify
the centrufigal superchargers will bolt onto the 2 valve engines the innercooler might need a special bracket to mount up to the new frame and the boost tubes will need to to custom made.
So larger injectors (fuel pump is a 255lph stock), a custom tune, and a couple pieces of scrap iron and 2 tubes and the '97-'03 superchargers will will work on the '04 and up 4.6 2 valve engines
Old Nov 1, 2008 | 03:27 AM
06yz250f's Avatar
if this is true, how come no one has been the guinea pig? if someone would do this and make a how-to i would definently consider this. i really want a supercharger over a turbo if i do decide to get blown. dont like the idea of tubing everywhere if i offroad
Old Nov 1, 2008 | 07:14 AM
Veteran: Army
Allen Engineering has installed a '97-'03 system on one of thier test trucks and it bolted right in. By running fuel mods and a tune you can avoid the fuel line issue caused by the FMU.
I will be doing this install by next summer, my 2001 F-150 is procharged and I will be remiving the procharger from that truck and installing it on my new bodystyle 4.6 along with 39# injectors, 90mm MAF, MAD's intake and crank pulley should push the 4.6 to around 15psi and still be streetable
The innercooler tubing looks like it will interchange but I will be running a dodge cummins air to air innercooler so I will not be using the ATI innercooler.
my green truck will be getting a modified mustang procharger F1A system so no worries for those that have been following the build on that truck
Old Nov 1, 2008 | 03:50 PM
08FX2's Avatar
you can call your dealer and buy a ford racing superchager for the 4.6 mustang, but you also have to buy a mustang throttle body to go with it. it would cost about 6k with install, i have been saving up to do this to my truck but i dont have the money to throw down right now. the 4.6L in the trucks is the same as the mustangs, except yours is a 2v and the mustang is a 3 or 4 valve, these heads can be bought at ford racing as well and will bolt right on.
hope this helps.
Old Nov 1, 2008 | 04:12 PM
06yz250f's Avatar
terajerame, when you do this, i will be following the thread. if it works as you say, i hopefully can do it as well. i don't like turbo charging idea with all that piping.
Old Nov 1, 2008 | 04:13 PM
Veteran: Army
there's more to the head swap then just bolting the heads on...
there's wiring and computer and drive by wire stuff that your 2 valve 4.6 truck is not equiped with...
hence why using a direct bolt on is more practical for most people
Old Nov 2, 2008 | 02:10 PM
Sc
I sell performance parts through keystone catalog and ford offers a performance upgrade for the 4.6 wich is meant for the mustang but is compatible with the f150(Few mods I imagine but kit seems to handle it) and with this the S/C will fit with few mods!!!I aint an expert but I've been lookin around for a while and this is the only thing i've seen with my eyes that could be easyly done with a lil $$$$$!!!!
Old Nov 2, 2008 | 02:13 PM
Proof
I'll scan the page somehow and post it sooo you could see for yourselves!!!!Like I said I'm no mechanic, I could be wrong, but it looks good to me!!!I'll try to post ASAP!!!!
