gear change, what a difference
well i took out the stock 3.55's and put in a set of 4.10's....what a difference! i guess i'll be giving mt a call to order a set of dynatechs. is everyone else satisified with theirs?
Put your curser over Private Messages at the top right side of the page under Welcome, 06BOSS and select it.
Edit Signature will be at the top left side in the Control Panel section. Select it and fill it in.
Just went and priced some 4.30's today to install on my truck in the next couple of weeks.
The Dyna techs are a good header but I was able to get a set of ceramic coated Pacesetters and the full true dual exhaust for 2/3rds the cost of the dyna techs. The only issue with the Pacesetters is that they supply crappy gaskets, just get new OEM gaskets and they work great. If you have a couple grand to throw at your exhaust then byall means get the Dyna techs and exhaust. I am very happy with my setup and I only have 1K in it total.
oh and when you edit your signature make sure you click show your signature in the miscellaneous options below the first submit button.
Well just finished installing my 4.56 gears from randy's ring&pinion and wow what a difference. Glad I went to 4.56's now i just need a custom tune to fix my speedo and that governor and take it back to the track.
You better have drag radials or slicks. I couldn't hook with 4.10s and street tires.
Going to be running nitto drag radials at the track.
I didn't pick them I would of gone with a slick but, I got them sponsored so not complaining what so ever
once I get a custom tune I'll go to the track.
