Heat Exchanger
Heat Exchanger
Im doing some preformace mods to the engine and I want to get a stock lightning heat exchanger. (Witch would be an upgrade from the stock magnacharger one)
But first I need to know what size the hose connectors are on the lightning exchanger. to see if I need a different hose's
Also has anyone used a stock lightning 01-03 heat exchanger on a 01 4wd?? (I'm shure your out there) Will it mount up with no mods to the stock lightning brackets is there mounting holes there already or do I need to drill ?? any pics of your install ??
Thanks for any help
Thanks for any help
well i think me and JMC and Built are the few with 4x4 and i dont recall built using a facotry heat exchanger? me and JMC didnt use the stock location, i think we both have winch's lol.
either way, the e-bay replacement (same quality as ford mfg) runs 3/4?
if u check out my thread in engine forum you'll see where i put mine.
Also has anyone used a stock lightning 01-03 heat exchanger on a 01 4wd?? (I'm sure your out there) Will it mount up with no mods to the stock lightning brackets is there mounting holes there already or do I need to drill ?? any pics of your install ??
Thanks for any help
Thanks for any help
It did on my 03.
Pretty sure the 97s are different then 99 up.
I would upgrade the inter-cooler tank/reservoir at the same time if I were you.
Phil
the stocker wouldnt fit my 98... I just upgraded to this one, which dropped my IAT2's 60* at wot!
http://www.frozenboost.com/product_i...035fd0c20031ce
