Boost Question
Originally Posted by malexander52
I am currently running an n/a 4.6L.
Can a low boost (psi) turbo be introduced to the system without engine modification, i.e. heads, shorter rods, etc.?
how many miles do you have on ur truck?
my truck is turbocharged, its an all stock block. but i have a 4.2l v6.
i made a thread in this section of the forum its called
'those with stock blocks and boost, post here' or something along those lines.
read that one.
you'll see that tons of folks here have some sort of forced induction on stock motors.
Grooviness
Originally Posted by tj03f150
yes.
read that one.
read that one.
Next Question
Originally Posted by phil6608
When you do the tranny,,,better put some high performance parts in there or you'll be doing it again before to long.
Phil
Phil
The 3.08 is killing me and I have been traveling too much for the past 6 months to get her swapped. I have to go out of town for a two weeks next month so I am dropping her off to get the 3.73s installed.
I may completely decide against a boost application if the 3.73s feel good enough.
I am open to any knowledge and tips you care to share.
Sure as a heart attack
Originally Posted by ONELOWF
The gears are the best bet, and may do enough.. Are you sure that you have 308's?
