lightning swap
lightning swap
Hi, any recommendations on a tuner or handheld tuner to use. I am putting a L motor into a 99 4X4 f-150 and want something on hand for the first fire up. Thanks...Karl
For all the little bits, as well as a tuner, get in touch with Mike at www.madenterprise.com or call Mike Troyer of Troyer Performance (they're a site sponser).
they both have lots of experience and will hook you up right. I used them for my L swap.
as for a tuner: hands down excal 2 from Troyer with tunes.
When you say your swapping an L motor, does that mean an L PCM as well> If so you don;t need a tuner up front. If you use the stock 5.4 PCM then you have no choice but to have a tuner. Troyers good, so is Sal from PSP.
