Supercharger issues
Supercharger issues
I get a check engine light and some light pinging at WOT sometimes. The code reader gives me a below threshhold error? I reset the code and it stay away for a few weeks. Should I be concerned about the pinging? This is with 93 gas in a roush intercooled supercharged 4x4 Supercrew.
Thanks in advance.
Chris
Thanks in advance.
Chris
Sounds like you are detonating. Better get your tune checked or stay outta the pedal. Have you noticed if it is really cold when it pings? (regarding you live in Delaware) I have to be easy during the winter because of the cooler temps cause mine will detonate at WOT....I also think it's the grade of 93 that I get. I don't believe it's the same every time
We have a tuner right in Middle-town DE if you want to get it checked out!
http://www.performance-evolution.com...ge/1739165.htm
His name is Matt and he dose all my work.
Phil
Phil
Phil
Phil
Thanks I will give him a call. Thats very very close to me.
I would have your injectors checked out. My truck started pinging till it welded the tip of the electrode. Found out I had a injector that had some big debris in it. The guy who rebuilt and flow tested my injectors said that ford went away with a internal screen on the 39lb cobra injectors shortly after they were in production. Once mine were cleaned he used the early style screen and installed it in all of mine. If you are running the stock Roush tune it should never detonate(ping) unless you have a injector going out, wrong octane gas, or bad gas with water in it. Did you just fill up with gas? Have you changed your fuel filter? Filter needs changing every 10K or so. Did anything change right before the pinging started? Anyway good luck on finding the problem.
Originally Posted by KTrostel
Wouldn't water in the gas lower the chance of detonation as the vaporization process drops the cylinder temps?
(edited to make clear)
I had about 3 gals of water in my tank at one time due to a leaking storage tank after heavy rains and i got horrable pinging because of it. When the truck would run it ran bad and everytime the fuel pump would suck the water up it would ping terrable then a puff of white smoke out the tail pipes would follow.
