Getting Ready for Pro Charger to Lightning Upgrade
Old Mar 3, 2008 | 09:44 PM
pol5002's Avatar
Just bought a Lightning unit off of Ebay. New pull off from 2001. Guess the Pro Charger has to go!! Just had my truck dynoed at Troyer, guess I'll be going back
I guess I will call Mad Enterprise and get some parts. Any install recomendations?
Old Mar 3, 2008 | 09:53 PM
built54's Avatar
get the kit from mike, and let troyer tune it, you will be happy.
Old Mar 3, 2008 | 10:18 PM
pol5002's Avatar
i will do both, Mike has been tuning the truck so far. Did you sell your truck? Wife would not let me make you an offer so on with mine
Old Mar 3, 2008 | 10:19 PM
built54's Avatar
haha.... no I Didnt, and Im glad I didnt. on with the mods!
Old Mar 6, 2008 | 10:37 AM
Veteran: Army
how much boost you running on the ATI??
Old Mar 7, 2008 | 10:38 PM
pol5002's Avatar
it was at 12 until I went to Troyer last time and he said we had better remove it to be safe before the dyno runs. so it is now 9
Old Mar 17, 2008 | 09:09 PM
justjames80's Avatar
Feh....should have just left it at 12. There are too many people running 12# ProChargers to lend any credibility to an argument that you might hurt the engine based on that alone.
Old Mar 17, 2008 | 09:35 PM
Veteran: Army
i need to bump mine up to 12# and tune it
Old Mar 21, 2008 | 10:57 PM
pol5002's Avatar
I was just going on his advise. I will not have to worry about it for long as the swap will near. Just have to decide 6 or 8 psi in the Lightning Blower??
Old Mar 22, 2008 | 10:37 AM
Veteran: Army
8psi gets my vote
Old Mar 22, 2008 | 11:21 AM
ONELOWF's Avatar
This is interesting ......http://www.nloc.net/classifieds/show...uct/4307/cat/7
Old Mar 22, 2008 | 01:06 PM
built54's Avatar
wow that is a deal!
Old Mar 22, 2008 | 03:52 PM
raider's Avatar
I went from the 9psi 3 core Procharger to the L swap and I am running 12psi with mine...good luck on the swap...Mike Dunn will help you out with any ?'s you have
Old Mar 24, 2008 | 09:52 AM
CobraKit's Avatar
I've been running 12 for about 30,000 miles then went to 14. About 5,000 miles. Engine appears to have damage to ring/piston. Oil coming out back when I hit the gas. Truck now has 125,000 miles on it. So, the question is not can it take it, its for how long. Yes, tune will help, but running high boost will damage stock hypereutectic pistons, its just a matter of time. And this is a daily driver, never drag raced!
Old Mar 24, 2008 | 02:25 PM
I've been seeing 13 - 14psi on my truck for nearly 3 years without issue. If something went bad, 90% of the time it's the tune. Wasn't the pistons' fault either. Hypereutectic alloy pistons are more sensitive to detonation but if the tune was spot-on that wouldn't be an issue. If LS1 cars can make 600+ hp with their cast, hypereutectic pistons and live with the abuse then it's obviously not that big of a deal.
