Blown Engine
Old Jan 20, 2008 | 02:01 PM
bixbystx's Avatar
Blown Engine
I have a 2003 F150 with a 4.6 V8 and a M90 supercharger with several other mods. I was driving home from church today and I gave it a little gas and it started shaking and smoke was coming out from everywhere. The oil pressure went down to nothing. I know I'm looking at a ton of money to get my truck bad and running. What would be my best options? I know I need to have someone look at it first to see exactly what the damage is.
Thanks,
Bixbystx
Old Jan 20, 2008 | 02:08 PM
4.2trimble's Avatar
its really hard to say without knowing the extent of the damage! but its going to probably come down to is it logical to pay X amount of money to fix my truck when i could pay X amount to buy a new truck. me personally i normally choose to fix my truck but i am attached to my truck!
Old Jan 20, 2008 | 06:37 PM
GerRod's Avatar
if the wire harness is not an issue between the 4.6 and 5.4, I would get one of these and have someone go through it. Maybe someone will join in with the answer.
5.4 Lightning engine
Old Jan 20, 2008 | 07:13 PM
CDB03STX's Avatar
Man that sucks. How much boost are....were you running? How many miles? Good tune? I'm just curious, I think we have the same truck.
I'm back and forth over a lightning swap or just a built 5.4 procharged. I think I will go with a 5.4 instead of a 4.6 WHEN the time comes.
Tough luck man
Old Jan 21, 2008 | 12:33 PM
Veteran: Army
how much damage? did you by any chance just lose a headgasket?
if it did blow look at the bright side:
at least you can build a forged engine now, I deffinantly recomend the 5.4 but you can easily build a 5.0/5.1 "stroker" out of your 4.6 that will run real well and add a set of stage 2 or 3 heads with a good set of cams and you'd be really happy. also then you'd be "re-storing" your truck to what it looked like before and you could leave your 4.6 stuff on the engine and have a real sleeper
Old Jan 21, 2008 | 05:19 PM
mrpositraction's Avatar
I wouldn't worry too much until you find out the damage. If it was just a gasket, that is easier to fix. But I alway like to use this opportunity to build a stonger, faster, and better motor.
Old Jan 22, 2008 | 11:35 AM
bixbystx's Avatar
Blown Engine
I'm not sure which way to go with getting a new motor. Do I try to find one at a salvage yard or what? I was also looking at a 5.0 stroker engine that I believe will work fine as a replacment. Does anyone know if this is true or not?
Bixbystx
Old Jan 22, 2008 | 12:55 PM
Veteran: Army
as long as it's a 4.6 based block you will be fine, you'll need a tune though
